Results 1 to 10 of 11
Thread: Surfjet!
    Nov 2004
    Homer, NY
    Surfjet!
    Well, I picked this up since I abandoned the ill-fated Canoe-ski project.
    It's a 1984 Surfjet 236ss Freestyle. 255cc Fuji twin, vertically mounted.
    Anybody familiar with these things? Any performance tricks? I understand that they only go about 25mph in good condition, I'd like to speed that up a bit....
    '03 Octane, Watcon 2318 CDI
    PWCToday.com Is My Home Away From Home Live2ride Powersports's Avatar
    Aug 2007
    LIVE2RIDE POWERSPORTS
    Re: Surfjet!
    I had one i bought for 50 bucks, but would be surprized if it did 15mph. It wasn't in great shape, but ran ok. Resold it for $250 a couple years ago.
    You will have fun with it, alot of attention from people to. LOL
    WORLDWIDE PARTS PIMP
    Live2ridepowersports@hotmail.com
    I accept Paypal, Cash, Checks, Money orders, first born child or trades for payment.
    Real men do it standing up!
    Re: Surfjet!
    those were made right here in janesville!
    cool old school stuff.
    email watcon@watcon.com
    Please visit our web sites
    PWCToday.com Is My Home Away From Home gto0209's Avatar
    Dec 2009
    madison wi
    Re: Surfjet!
    does it have a pump or prop?
    Aug 2007
    Re: Surfjet!
    Quote Originally Posted by gto0209 View Post
    Pump style
    Nov 2004
    Homer, NY
    Re: Surfjet!
    The board was about 30 lbs overweight. Should weigh 130lbs and mine weighed 162....
    Let the refoaming begin!
    PWCToday.com Is My Home Away From Home Minnetonka4me's Avatar
    May 2002
    Minnetonka 'I'm on Big Island I3itch!!!'
    Re: Surfjet!
    Theres some guy up here that has 4 of them...and thinks he's gonna get $2500. LOLOL
    Nick @ www.WestsidePowersports.com -your Seadoo specialists!!
    Current machines being parted out -=click below for pictures=- PM for availability & pricing
    Nov 2004
    Homer, NY
    Re: Surfjet!
    I guess I need to start a build thread, but for now, here's a few photos of what I did.
    The combustion chamber design is a total disaster. The angle of the squish band is backwards! We wound up using a comparator to determine the angle of the piston, at 7 degrees, made a jig to spin the head on a lathe, and then milled that angle into the head.
    Then, rechecking the squish showed a 2.7 mm gap. So we milled the block a full 1.8mm, to close the gap up to the recommended 0.9mm squish for this diameter piston (.9 pulled from Bell's book)
    Cutting the head increased head volume from 9.0 to 9.6cc. Skimming the block by 1.8mm countered this, and then some. The stock SurfJet has a compression ratio of 11.0:1 , the modified head calculated out at 11.8:1. I also checked it old-school style, where I put the piston at TDC, replaced the top ring with an o-ring, and also smeared some grease between the piston and cylinder, and then used a burette to fill the combustion chamber with kerosene. Doing it this way is most accurate, and I came up with 12.0:1, right in the middle of Premium 91 territory.
    The carb from a 1988 EZGO golf cart fit the intake manifold with a few modifications, and is 2mm larger than the stock BV22. The EZGO uses a BV24.
    Refoaming dropped nearly 30 lbs from the weight of the board, the stock foam was very waterlogged.
    Trying to find replacement reeds led me to the Boyesen model 423 for the Suzuki DT15 outboard motor, or custom ones made by TDR Racing out of Punta Gorda, FL. Tony at TDR is awesome, his reeds look perfect and cost $20 a set. The Boyesens are $80.
    PWCToday.com Is My Home Away From Home MCrider's Avatar
    Sep 2009
    Jackson MI
    Re: Surfjet!
    that this looks pimp! great job
    1990 fixed steer SN SJ with bolt ons
    http://www.pwctoday.com/f72/fixed-st...sj-341918.html
    Quote Originally Posted by monSTIer View Post
    Smaller waterbox or you can clearance the waterbox with a trusty old persuasion device.
    May 2002
    Re: Surfjet!
    Dude you are the freakin restore MASTER!! Holy crap that thing has 10 time the R&D time that the manufacturer did!
