Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    Feb 2010
    Tennessee
    winterizing stx-15f... what do i need???
    this is the first ski ive winterized, its an 05 stx 15f. should i put anitfreeze in it or just get all the water out of it? and how is the best way to get antifreeze in it??? should i drain all the gas out or just add some stabil to it? i know to disconnect the battery and lube up everything. but im just really not sure what the best things to do are. any help is greatly appreciated! thanks, michael
    Frequent Poster CJ River Rider's Avatar
    Feb 2008
    Central NJ
    Re: winterizing stx-15f... what do i need???
    Get fogging oil, never seez, marine stabil, and a good trickle charger and follow the instructions in your owners manual. I don't add antifreeze but I drain/blow out the machine exactly the way they tell you in the OM. A lot of people here will tell you to get anti-freeze, but being in the AC/Refrigeration business, water freezing is a problem only if it's under pressure and cannot expand when freezing. I have an 08 STX-15F and a 97 GP1200 and never had any problems.
    Sep 2007
    Shuswap Lake, Canada
    I haven't done the anti-freeze trick, but I do drain the exhaust system fittings very well and tilt the trailer tongue WAY WAY up to get as much water out as possible. Follow the book to a "T"....if you miss something it will be a sad day for you come spring. If you don't know, ask.
    Feb 2010
    Tennessee
    i really appreciate the replys. i was mainly just concerned about getting all of the water out, i'm a little confused about the hoses they refer to in the owners manual so i was thinking that if i did the antifreeze "trick" then i would eliminate that problem. i was assuming that the "trick" is to hook a hose up to where the waterhose outlet is and suck antifreeze through it that way until it blows pink out the back? plz correct me if i am way off.
    Sep 2007
    Push the antifreeze, as opposed to sucking it! But not too much or it will get into the cylinders after filling the exhaust system
    Feb 2010
    Tennessee
    dang, thought i understood the antifreeze but not sure now, what do you mean by "pushing" it instead of "sucking" it? (that sounds really perverted. lol)
    Sep 2007
    Well, the hose connection relies on water pressure to feed the cooling system,right?? The cooling water then exits out the exhaust and pump. DON'T try this unless you have read the manual.....or you could easily damage the motor by filling it with coolant.
    The manual is pretty good, you know!
    Feb 2010
    Tennessee
    ok, last question. if i tip the jet ski up and crank it up, will that be enough to get all the water out? or do i need to disconnect the hoses?
    Sep 2007
    The book says to remove that lower hose I mentioned earlier, tip it this way and that, so it drains, then you can re-attach it snuggly. It's not that hard to do and you WILL get some extra water out for your efforts
    Feb 2010
    Tennessee
    alright, thanks, thats what i'll do.
