Results 1 to 10 of 15
    PWCToday.com Is My Home Away From Home cavemanX2650's Avatar
    Jun 2009
    Austin TX
    swirl dome head for a 650 kawasaki ,..how much compression ?
    surely somebody has to know ,....
    Top Dog Bar Tab's Avatar
    Jan 2009
    Los Gatos
    Re: swirl dome head for a 650 kawasaki ,..how much compression ?
    It looks like they made two form the Ocean Pro 1991 Orderbook.
    Pro 650 AVX Aluminum Head Race Gas- EP105
    Domes shaped for race fuel
    Designed for high compression motors
    Dyno and race proven
    27% more cooling volume
    3 cooling line bosses
    Additional mass above domes
    Domes recessed .040
    Mill up to .040 without recutting domes.
    Pro 650 AVX Aluminum Head- EP100 Pump Gas Domes
    Domes shaped for 95 octane or lower
    Horsepower gain throughout powerband
    Domes recessed .040
    Not sure that this is much help
    Jun 2009
    Austin TX
    it gives me a starting point !! thanks
    Jun 2008
    bremerton wa,
    185 psi I was told with a stock gaskette
    Jun 2009
    Austin TX
    Quote Originally Posted by anthony View Post
    LOL j/k
    Banned motoman96's Avatar
    Aug 2008
    Under a ROK....literally
    Cavey, that head will put you around 318psi, just run pump gas an hold it WFO as long as you can.lol
    Jun 2009
    Austin TX
    Quote Originally Posted by motoman96 View Post
    sounds great M&M , ill try it out in the morning and post back with my results
    PWCToday Newbie bellamy24's Avatar
    Sep 2009
    Columbia, SC
    Hey Caveman, did you ever end up using this head? I came across this thread and have the same head on my ski where it makes 210/215psi.
    __________________________________________________ ____
    '89 650sx silver, Ocean Pro head, .50 over, 44 mikuni, '86 coil, 15.5 impeller, K&N FA, bilge.
    '92 650sx stock
    Top Dog rhugo21's Avatar
    Jul 2010
    Santa Monica, CA
    I bought this from caveman about a month ago....does it really make 210 psi? What kind of head gasket are you using?
    2017 SJ
    1988 550 w/PJS Viper 700
    Midwest Wave Warriors
    Sep 2009
    Columbia, SC
    These readings were taken on 4/28/2010 that I found in my phone and are actually higher than 210. They may have been taken before the ski was actually run so they may not be as accurate as the consistent 210/215 I've been getting since running it. Not sure about the head gasket, is there an easy way to tell? This engine was built by a shop in upstate SC I was told when I bought it so unsure of all the specs other than the .5 overbore and new top and bottom. I put it into a ski I built and ran it for the first time. I'm halfway expecting it to blow up or melt every time I ride it.
    '92 650sx stock
