Rad Dudes Gen2 X2 Top Deck Build GTX2 - Page 3
Results 21 to 30 of 40
    Top Dog JeffX2&SX's Avatar
    Austin, Texas
    Re: Rad Dudes Gen2 X2 Top Deck Build GTX2
    Cool Mark. I'm excited about verifying the fit of the plate.
    2004 SX-R - RRP handlepole, Advent Ignition and TBM handling
    2005 GTX2 - SE Steering, Advent Ignition, Factory Wet Pipe and TBM handling
    Aug 2008
    CT
    I have had a ton of PM about what all you need to build one of these so here is a bump
    Ok Everyone has been asking me for a list of the odd ball things needed to build this ski once you buy the Top Deck kit from George
    So here is the list
    1- SXR
    1-Top deck kit
    Comes with
    Rad Dudes Hood hinge
    Rad Dudes Front and Rear Seat Hold downs
    Parts from the kawi dealer
    Steering Cable Bracket bolts right under the hood, You can run the SXR Cable but it is long and ends up shoved way up in the waterbox area. Jonny X2 has a guy who is remaking the X2 Cable for I think $80 and it fits like a dream.
    1----- 14044-3714 HOLDER-CABLE STRG $2.10
    1----- 14044-3717 HOLDER-CABLE,STEERING $14.68
    You need a 2nd hood latch for a SXR this is a 2008 part number for the black one. I went grey on mine and got sxi ones. Gen1 X2s dont work.
    1---- 27012-3711 HOOK $25.62
    1---- 27016-3703 LOCK-ASSY $113.03
    Since you cant bolt the hood side on you need Rivets, this is the part number for the SXI, i used these and they held great. Im sure you can find cheaper but this is what i used.
    4---- 92039-3750 RIVET $4.24
    You need a hood seal, this is the part number for the SXR one. I used a tunk seal that can be found at any auto parts store. It was I think $20.
    1---- 39145-3781 TRIM-SEAL,L=2156 $33.35
    The seat, it was used on a list of different kawi dirt bikes over a number of years. 2002 Kx85 was one of them. Aslong as the plastic seat pan says 53001-1619 on it, it will work.
    1------- 53001-1937-MH SEAT-ASSY,GREEN/BLACK $161.43
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Top Dog tvcracer's Avatar
    Aug 2010
    Illinios
    Perfect Twin this will help us all.
    Austin, Texas
    I'll add that if you are getting the SE steering you will need the grommet harness and plate ***'y. This is how the modern Kawasaki skis neatly hold the throttle and start/stop cables as they go through the hood. The SE steering has the hole and threaded holes to accept this. It's WAY cleaner and easier to use than the old X2 "feed it through a rubber sleeve" method.
    Part numbers are:
    13271-3905 Plate - $7.94 from www.watercraftsuperstore.net
    92071-3790 grommet/harness - $6.18 from www.watercraftsuperstore.net
    Aug 2010
    Illinios
    Thanks Jeff, great info.
    Austin, Texas
    funny, I abbreviated the word assembly and the forum asterisked the A$$ in A$$'Y.
    Aug 2010
    Illinios
    I got it, you type better than me, LOL
    Austin, Texas
    Heres the grommet and plate in place...very clean
  9. #29
    Aug 2010
    Illinios
    Very nice and clean look, thanks Jeff
  10. #30
    I dream skis tjindo16's Avatar
    May 2009
    Citrus County, Fl
    sick ski man,,,, very nice color choice! lets see some pics of it in the water
