SXR 1100 triple pic's , and mod's build thread - Page 375
Page 375 of 376 FirstFirst ... 275325365373374375376 LastLast
Results 3,741 to 3,750 of 3752
  1. #3741
    Re: SXR 1100 triple pic's , and mod's build thread
    Quote Originally Posted by Waxhead View Post
    Hey here is a weird one, I have what I thought was a sxr bed plate with a stx1100 shaft and it puts my mount holes like this
    Wax, STX shaft works with 1100 mounts. You need to drill/tap one hole for 1100 mount. Put mounts in with the rearward mount bolt, and then drill/top for front mount bolt.
    Looks like you have the stock SXR mounts. These will work as well, but with these you use a 750SS drive shaft.
    Hope this helps.
    email watcon@watcon.com
    Please visit our web site
  2. #3742
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    SoCal
    You can also use the 650/750/800 bed plate and mount to the stock holes using a 750SS shaft. Just need the ADA coupler.
  3. #3743
    PWCToday Regular 98GCLimited's Avatar
    Aug 2015
    LHC, AZ
    Well this ski isn’t a new build but I tore it apart to do some maintenance and upgrade a couple things. Fixed a bunch of chunks of gel coat out of the strakes and chines, some small gouges, dings and scratches on the bottom and switched from Blowsion Destroyer tubbies to Prowatercraft front sponsons. The bottom was pretty rough to say the least from previous owner(s) and whoever installed the Destroyers should never touch a ski with tools, they were way too far forward/low and on top of that the left side was about an inch further forward than the other and both sides were gobbed with black silicone around the edges.
  4. #3744
  5. #3745
    Hi guys,
    Just wondering if you could please help me with jetting.
    Have Kawasaki sxr1100
    48mm novis
    Stock bore size
    Stock barrel
    Ada head
    155 psi compression
    145 pilot
    135 main
    110 jet in return line.
    Have real bad flooding down low. Revs out up top but struggles to rev out from the bottom.
    Has anyone got any baseline settings to run from?
  6. #3746
    Top Dog cman's Avatar
    May 2005
    i can see you
    125 pilot 125 main 2.3n/s 115g spring with a 60-90 jet in the return line. Worked great for me
    Check out Poor Boy Racing on Facebook
    https://www.facebook.com/poorboyracingteam
    Need parts? Optima Racing is the place
    http://optimaracing.com/
  7. #3747
    Aug 2015
    LHC, AZ
    So idk if anyone needs these but I remember reading that it was basically impossible to find in some older threads on the topic.
    The accelerator pump diaphragm for the 1100 cdk2 racks, I got this one from tomski here in Havasu, he’s a hot products dealer and have had this for a year now and I wasn’t sure it was the right size and sure enough it’s the right part.
    Genuine keihin replacement part, hot products part #1201-829-2102.
    My diaphragm looked fine when I took it out but I replaced it anyway with this new one. At the time I bought this I had what seemed to be a weak squirt from the accel pump so I bought the new diaphragm in case I needed it.
  8. #3748
    PWCToday Newbie Fiftyfiftyone's Avatar
    Oct 2019
    Washington
  9. #3749
    PWCToday Regular Marsig58's Avatar
    Feb 2011
    Perth, Western Australia
    I just installed the PJS timing advance into the 1100 timing cover. I had to grind away the timing cover to make it fit.
    Do I now have to grind the top engine casing so this will fit?
  10. #3750
    PWCToday Guru ///M5's Avatar
    Aug 2012
    Guam
    Quote Originally Posted by Marsig58 View Post
    I actually ground away some of the sensor housing
    Sent from my SM-G981U1 using Tapatalk
