SXR 1100 triple pic's , and mod's build thread
Page 1 of 376 1231151101 ... LastLast
Results 1 to 10 of 3755
    PWCToday.com Is My Home Away From Home Super 1's Avatar
    Aug 2010
    NW
    post up pic's of , and mods for the sxr 1100 builds , i am going to do one , and would like see/hear what ideas you guys have , that are doing this build .
    tomorrow morning i am going to pick up a zxi 1100 that i will be using parts out of for this build , i am going to us the 85# ski in these pic's for the build .
    Obama is a dirty gutter crawling african maggot ! .. so is his dirty wife MOOOCHY .. the " MOOCHER "
    blood sucking sucking liberal dirty 2 faced RAT's !
    some day i will till ya how i really feel .........
    I dream skis eel's Avatar
    Oct 2005
    down under
    Re: SXR 1100 triple pic's , and mod's build thread
    Just today, I have finished the internal hull grind. No bond glue anywhere and internal surfaces are SMOOTH!!
    Not running triples, just modded 1100 pipe. Looked at the rogue 900 setup but won't work with my engine as it will make target rpm with fat 1100 pipe.
    our home is girt by sea
    Oct 2009
    Jersey Shore
    AWESOME!
    Between you, Scottie, Jason and a handful of others builds featured here, it's getting all us followers pumped for our own!!
    Aug 2010
    NW
    Cool ! this thread should be some fun with all you guys on it for sure !
    after a 7 hour drive round trip i now have my ZXI 1100 , this ski is so clean for a 96 , it was always in a garage with a cover over it , i almost hate to rob the motor out of it !
    i might through the 800 back in it from the 85 ski , for my kid to ride , and set buoys out .
    i did a compression check on the motor, it was perfect and the same on all 3 cylinders , sounds great, fires right up .
    a few pic's of the ski
    Aug 2010
    NW
    Quote Originally Posted by eel View Post
    what are you running for carbs ?
    PWCToday.com Is My Home Away From Home sxr951's Avatar
    Aug 2007
    Mecong Delta, Florida
    can u make make this work? 1300 cc
    09 SUZUKI HAYABUSA GSXR 1300 ENGINE MOTOR KIT 2009
    http://cgi.ebay.com/ebaymotors/ws/eB...t_12805wt_1165
    PWCToday.com Is My Home Away From Home Ragged Edge Racing's Avatar
    Dec 2004
    SoCal
    You probably could but it wouldn't be legal in any class, today anyway...
    Aug 2007
    thats ok. i just want to hit 70mph ( no trailer jokes please!) lol
    ever since i put the front sponsons on i could look back words while wide open throttle
    Oct 2005
    down under
    I'm going for 70 as well. (well give it a try??)
    3mm stroker, 82mm sxr pistons, old race igniter, side draught 47 brms, delta 3's, eel case and cyl porting, modified 1100 pipe, hollow waterbox, backpressure restrictor in bulkhead tube, lightened and ground hull, pump to be decided.
    2 packed the engine bay and fooked it!! Need to sand back and get someone who knows what they"re doing to paint it. Should just stick to engines......
    Oh yeah, fellow 1100sxr'ers, why don't we stick to this thread instead of starting new thread for individual boats? That way we would have a one stop encyclopedia of 1100 sxr's instead of jumping threads to see whats going down.
    Aug 2010
    NW
    on the inside of the motor compartment use 2 part epoxy with colorant added to it ,
    west systems is a good one , mix maybe 2 cups at a time because it sets up fast , use a brush to put it on ,
    use cheap throw away brush's for this because you will need several
    this is the best way to do it because if you ever have hull damage you just sand it mix more epoxy and glass , add the colorant , make the repair , if you used paint you would have to grind all the paint off before you repaired , plus this adds strength to the hull .
    a few pics of my kawi doo hull after this was done on mine . to give you and idea what it looks like after
