Project SXR 1100
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 126
    Resident Guru Dano 7's Avatar
    Nov 2003
    PA
    Project SXR 1100
    Well here we go with another SXR 1100 build. My goal is a 60mph reliable pump gas ski.
    I picked up a 99 ZXI 1100 and trition trailer from a friend of a friend and a 04 SXR hull from Eric Malone @ www.ericmalone.com
    The ZXI is in good shape but the Ebox needs attention and the front cylinder only has 70psi. So the Ebox is at www.jetskisolutions.com and john is going to do up a custom box. I will do a new topend and send out the crank to www.crankworks.com for a rebuild.
    The SXR was one of erics boats that he ended up taking the engine out of to put into one of his custom hulls. It needs some fiberglass/gelcoat work but he hooked me up with it for good deal. Eric was great to deal with. Also he had a STX driveshaft that I purchaced.
    So, I'll be posting what I am thinking as far as setting this ski up and what components I will be using. I will need some help on the do's and don'ts and what works on getting to my goal.
    Any help is greatly appreciated.
    Dano 7
    96/99 ZXI 1100 - Parting out. Have engine & ebox and misc stuff. No hull. PM me for other needed items.
    04 SXR 1100 - For Sale. PM me for details
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Oct 2009
    Jersey Shore
    Re: Project SXR 1100
    Nice. I'm making my list of parts for mine this winter.
    Frequent Poster Lust4Thrust's Avatar
    Jan 2010
    Northwest Illinois
    Nice...Looking forward to seeing the build. Hey, maybe you should sell that beater under that car cover to make room for more skis. Just kidding - Nice ride.
    2007 Superjet
    1992 Superjet 650
    Nov 2003
    PA
    Quote Originally Posted by Lust4Thrust View Post
    Thanks. Got plenty of room for more skis. Never getting rid of the 61 vette.
    Dano 7
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Chicago / Portage, MI
    Lol a beater or something. Look up what one of those is worth in case you don't know...
    Sweet build and 61. Now I just need an 1100 myself...
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Nov 2003
    PA
    Update. Hull is going out for some repair in the next week.... Buying parts and making a list on what all is needed....Need to start tearing down the ZXI and get the engine removed.... Need more time..... I'll update again soon.
    Dano 7
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Frequent Poster miahs x2's Avatar
    Jul 2010
    so cal
    Cool build keep us posted
    Nov 2003
    PA
    Here is a little look on whats under cover #1
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Some current pics before it hits the body shop.
    Dano 7
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    So here is what I am thinking as far as the setup.
    Engine - Stock porting... Head mod with compression @ 150psi max (91 pump gas safe)... Rebuilt OEM crank, welded and trued... SXR 800 bed plate... ZXI motor mounts...New seals/gaskets ect...
    Exhaust - Stock system with 180 to SXR waterbox... Where to buy the 180 U bend pipe??? What is the hot setup to dry it out??? Waterbox mods???
    Ignition - Jetski Solutions custom box... 3 deg timing advance by bypassing air temp sensor??? Keeping stator cooling.
    Carbs/Intake - 44mm Mikunis on 1.5 SXR 800 R&D dominator intakes with reed stuffers and spacers... Blowsion trip pickup.
    Pump/Drive - Stock pump with TBM super pump cone...Duel cooling fittings to engine.. STX drive shaft...ZXI couplers... Impeller and nozzle sizes??? Skat or Solas??? 82 reduction/ 85 steer ???
    Hull - Blowsion Destroyers...TBM intake grate.. Ride plate??? Stock hood mod for more air....AC handle pole..TBM turnplate... UMI extended bars... TBM bumpers.. Hydroturf mats with kicker.... Blowsion rail caps...
    I am sure I am forgetting something and will be adding more. Any input on some of the mods and sizes that I need is greatly appreciated.
    Dano 7
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
