the rev limiter is always on the ski is hard to start the rev limiter just turns on when it wants to them some times it works great. help??????????????????
1994 yamaha fx1 runs but the rev limiter
Collapse
X
Re: 1994 yamaha fx1 runs but the rev limiter
do i need the book NO i have one thanks
my buddy said he thinks the cdi is bad too
if i cut the pink wire then i will not have a rev limiter i think i want a rev limiter
HOW much is a new cdi???????????
Comment
Comment
rev limiter is in the cdi...
pink wire is over heat sensor.. i have had over heat do this before.. its 2 wires in the ebox disconnect the pink and black if its still the same way then id say its the cdi
but you have a book it tells you what to do..At least when my string hangs out I still ride...
brad
Comment
Comment
