loud popping and not starting.
Results 1 to 10 of 19
    Jun 2010
    grand rapids michigan
    ok so my seadoo 98 gtx limited wont start and when i try to crank it was crank/almost turn over and then a loud pop..and at the moment i cant get it started..i put in some old gas i found under our deck that was there for about a week. only like 3 gallons maybe 2. should i empty that out then put new fresh gas in and see if that was the problem? i just replaced/rebuilt the rave valves.ill try to get a video up later tonight so you guys can see what im talking about. i have a video on my phone and i can text it to someone if they can seriously help me id love it..please i cant afford to take this to the shop..my step dad didnt want to get this seadoo in the first place and if i fix it. worse case. we will take it to the shop with an angry step dad. but i would like to fix myself...PLEASE HELP
    SEA DOO 1998 Sea Doo GTX limited
    PWCToday Guru mfear's Avatar
    Jul 2010
    fort lauderdale
    Re: loud popping and not starting.
    i sent you my phone #
    Jun 2010
    thanks you
    Jul 2010
    fort lauderdale
    vide doesnt work on my iphone..its grainy and no sound.. hrmm
    did you try draining the gas and adding fresh? does it stutter while its trying to turn over or does it just start to go, pop and stop? if you hold the start button will it keep trying to start?
    PWCToday.com Is My Home Away From Home tfergusonracing's Avatar
    Nov 2005
    Right in the lumberyard, Danny...
    I doubt the gas is the issue.
    It takes a big man to admit when he's wrong. I am not a big man.
    Jun 2010
    ill upload a video on here give me a minute..i got a crappy phone sorry
    Jun 2010
    nvm for camera adapter...well..uhh well i try to start by holding start and it cranks then right when its about to start it just stops some times. and then after that i keep trying to crank and then it makes a loud pop and stops.i dont really wanna bring it in
    Nov 2005
    If you have a major issue and you keep trying to start it, you're only going to make it worse...
    Jun 2010
    i stopped
    PWCToday.com Is My Home Away From Home bkoche's Avatar
    Jul 2009
    Centerport NY/Downers Grove IL
    timing off?, sheared flywheel key?
    2004 SXR - FPP Wetpipe, Blowsion railcaps, 4deg bars, billet clamps
    1994 750sx - Loaded -FOR SALE
    1983 JS550 - WC RC520 reed cylinder, WC Head, PJS WB, Dual 38SBNs, WC 750 reed stuffers, WC Stacks, WC 6.5gal tank, FPP Halfpipe, SBT High torque starter, 16.5 Skat, Blueprinted 440 pump, lightened driveshaft, 76mm OP nozzle, Jetsport bulkhead brace, 90wt mod, WC scoop, Rend plate, Rear exhaust, Carbon Fiber
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
