loud popping and not starting. - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    PWCToday Guru eeerieski's Avatar
    May 2007
    Somewhere in OH/PA
    Re: loud popping and not starting.
    what is your compression in the cylinders?
    1993 701 SJ
    1994 750 SX
    PWCToday.com Is My Home Away From Home gto0209's Avatar
    Dec 2009
    madison wi
    sounds like a broken woodruf key, probably a pricey fix, find a local guy, dont take it to the dealership.
    Charlie
    95 sc yami 760
    94 blaster 1100
    97 sj
    Looking for a complete coffmans sc pipe and waterbox, pm me if you have one
    PWCToday.com Is My Home Away From Home bkoche's Avatar
    Centerport NY/Downers Grove IL
    woodruf key should be super cheap, just a little labor intensive. do it yourself
    2004 SXR - FPP Wetpipe, Blowsion railcaps, 4deg bars, billet clamps
    1994 750sx - Loaded -FOR SALE
    1983 JS550 - WC RC520 reed cylinder, WC Head, PJS WB, Dual 38SBNs, WC 750 reed stuffers, WC Stacks, WC 6.5gal tank, FPP Halfpipe, SBT High torque starter, 16.5 Skat, Blueprinted 440 pump, lightened driveshaft, 76mm OP nozzle, Jetsport bulkhead brace, 90wt mod, WC scoop, Rend plate, Rear exhaust, Carbon Fiber
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    Jun 2010
    grand rapids michigan
    does any one here in the michigan area do sea doo repairs for less then dealer ships? and i could barley do my rave valves :P..thats a lie it just took a while for the part. if i could get help id try to do it myself again
    SEA DOO 1998 Sea Doo GTX limited
    Northeast PA
    just by chance is there a possibility you got the plug wires mixed up
  6. #16
    Quote Originally Posted by carp645 View Post
    On a 98 the coil fires both plugs at the same time,so it wouldnt matter which plug wire is on the plugs.
  7. #17
    The problem probably has a LOT to do with this.....
    http://www.pwctoday.com/f15/sunk-290139.html
    Water in carbs & or broken/worn reeds are my guess.
  8. #18
    Jun 2010
    ya but it ran for about 2 weeks after that just fine
  9. #19
    Quote Originally Posted by water worx View Post
    water in carbs & or broken/worn reeds are my guess.
    x 2
