94 750 SX oil injection block off
Results 1 to 10 of 18
    PWCToday Newbie suicyco's Avatar
    May 2010
    Torrance
    Ok, here's another block off plate thread, my apologies. I've researched the threads and I'm pretty sure I have the right idea however in most of these threads I read there's verbiage that throws me off.
    I read things like oil block off "kit" and "cables" going from the oil tank to the stator. I took off the oil pump from the front of the engine. There's two lines hooked up to it. One from the oil tank and one small one from the pump to the bottom of the carb. No cables! I ordered a block off plate, not a kit.
    It seems simple enough, remove oil pump, install plate. Remove oil tank along with the oil line that went to the pump. Shorten and plug injection line that ran from the oil pump to the carb. Is there more to it than what I just posted? Does plugging the line to the carb create an issue with anything? Any insight would be very helpful.
    Re: 94 750 SX oil injection block off
    yeah its pretty straight forward just pull the pump and the tank and you will have to remove the studs that hold the pump on and the plate should come with bolts and little caps that you put on the nipple thats on the carb for the oil line
    Quote Originally Posted by superhondaz50 View Post
    I hear a crunch crunch which believe is coming from the bearing box, it sounds like someone quietly biting a Dorito chip.
    It's not the size of your ski it's how you use it.
    Bring em back!!!!
    http://www.pwctoday.com/f29/i-demand...nt-287188.html lets bring charlie back
    May 2010
    Torrance
    Excellent, thanks for the quick response.
    no problem and also there is an o ring that is on the pump that i put on the block off plate instead of usin silicone you will see it when you take the pump off
    Bring em back!!!!
    May 2010
    Torrance
    got it, thanks again
    Aug 2018
    Texas
    Quote Originally Posted by Huckleberry64 View Post
    How do you remove the studs?
    SE MI
    Quote Originally Posted by keck View Post
    Just depends on the blockoff you have. Westcoast made one that used the original studs, all the others use small bolts.
    Aug 2018
    Texas
    Know this is an old post; yet avoiding starting a new thread. Given that the Xi has electrical wires that run to the oil light on the dash... what do you do with these wires once you remove the oil tank?
    PWCToday Regular N.Penley's Avatar
    Aug 2017
    Boone Lake, TN
    Id like to know the answer to this also.
    SE MI
    You can trace them back to the ebox and remove them. Or you could just unplug the devices and forget about them.
