crank case drain plug block off install with pics - Page 3
Results 21 to 30 of 33
    Aug 2008
    CT
    Re: crank case drain plug block off install with pics
    John at RCJS also sells these plates. That's where is buy them. With the motor in the ski the plate is just easy.
    RAD DUDES
    www.RadDudesFI.com
    www.Jetskiporn.com
    Jun 2010
    H'ville, AL
    I used a couple of 1/8" NPT pipe plugs. Worked sweet
    Justin
    2 650sx's
    1 XP
    Bunch of 4x4's and go fast cars
    PWCToday Guru SIMPSON's Avatar
    Jun 2010
    Concord, NC
    i installed a plate on my 650sx and stripped the holes i circled in red would it mess up the crankcase if i tapped them. Get metal shvings in it or what?
    Jun 2010
    Las Vegas
    I haven't had my engine out so I don't know if the 2 screw holes are threaded all the way into the engine. Gotta ask some of the gurus on here that tear their engine apart on a weekly basis.
    While we're at it, in a stock set up (with the stock drain plug intact), if there is water in the drain hole, is there pressure pushing the water or does it just sit there until the plug is pulled to drain it?
    Oct 2009
    whittier, CA
    yes if you tap it metal will get inside the case. and dont use long bolts you only need a 1/2 of thread to seal it.
    simson i recomend you just retap the treads or heilcoil the plate boltst unless your going to rebuild the motor soon
    86 x2
    Jun 2010
    Concord, NC
    can't you lube the tap up with some grease to get all the metal shavings?
    Frequent Poster sori___'s Avatar
    Jun 2009
    Lake Champlain
    you need to lube it when you tap it to help it cut the threads.. but honestly for the price of gaskets and such maybe you should just give it a quick overhaul and get that sealed correctly.. otherwise you will probably be giving it an overhaul because of the leak.. only it will cost more then a set of gaskets.
    Jun 2010
    Concord, NC
    what do i need to do to do it correctly?
  9. #29
    PWCToday Guru skidoo99's Avatar
    Oct 2007
    pelham nh
    there were multiple options given in this thread. pick the one that is easiest for you and go with it. they are all good tips and will work. or would you like me to come down and do it for you??
    91 x2 flatdecked with all westcoast bolt ons
    87 x2 hull, new flatdeck project
    92 750 sx, in its remodel stages currently
    92 550sx
    91 300 sx
  10. #30
    Jun 2019
    TX
    Wow! This helped me so much. Thank you for the pics. This is my first time tackling any job like this and I was very intimidated. Your pics showed me exactly what I was looking for. Thank you for sharing.
