Results 1 to 9 of 9
    Frequent Poster Mentzel's Avatar
    Oct 2005
    Anchorage, Alaska
    sxr 800 advent ignition (switch settings)
    Does anyone have an Advent t3 box with D5 curve set? I'm trying to figure out the dip switch settings to use curve #3. Advent has not responded yet and I need the info for this weekend. I've got the curve sheets, just need to know how to set the dip switches to match the curve. Not sure why they don't post this as well.... curve data is kinda useless without the switch settings.
    Larry
    Jon's World
    Re: sxr 800 advent ignition (switch settings)
    Switch 6 on and switch 7 off (at switch bank A) for curve #3.
    Switches 1 thru 5 are for rev limiter programming.
    .. Joykiller Racing - Skiwi Rentals - Pyro Images - Bomber Eyewear
    ................Newmiller Machine .-. IMPROS. - ..Rad Dudes Racing
    .....................Hartlauer Signs & Manufacturing - KMG Racing
    Oct 2005
    Anchorage, Alaska
    Thanks do u have a copy of the switch setup sheet I can have?
    Jon's World
    Its all on their website you can download it from there.
    Oct 2005
    Anchorage, Alaska
    Thanks I found the curves but not switch settings. Do you have a link?
    Jon's World
    products > T3ignitions > more information
    http://adventignitions.com/userManual/SXR-user-b.pdf
    Jon's World
    Did that give you what you were looking for?
    Oct 2005
    Anchorage, Alaska
    Yes got it thanks!
    Oct 2005
    Anchorage, Alaska
    Motor seized.. Grrrrrrr
    The d5 box set to curve #3 seems pretty aggressive to me for pump 90. Can anyone confirm this? Scratching my head on the seize up.
    Ski is spec limited with FP wet pipe, tbm step dome heads (29cc), .060 base gasket, oem carbs set at 82.5 pilots, 155 mains, 1/2 turn out on HS screws. Advent t3 (d5 curve set) set on #3 curve. 82.5 mm bores with wisecos set to .006" clear.
    Plugs and domes are powder black (deto) almost turning brown. So I know it is close but a little off some where.
    Want to run on pump 90...
