    Jun 2010
    seattle
    2006 vx110 oil filter
    Ok I got found and bought amsiol and ordered amsoil filter online and now starting to change oil and can't find the oil filter!!!! I know laugh but I have shoved my head and hands all over that hull and can't find it! help!!!!
    Jun 2009
    Re: 2006 vx110 oil filter
    Its located on the left hand side of the ski as you are sitting on it, its just below the voltage Regulator which is a ridged square metal box, its hard to see but its below the regulator. Its VERY hard to remove !!!! You would be better off to run the ski on the hose for about 5 mins to warm it up, much easier to remove. Its better if you remove a section of the exhaust, its much easier to get at. I used a ratchet and strap, remember to loosen it to the left ! Remove the oil with a suction pump/device. Place an old rag under the filter to catch any spills, remove the filter. Remember to oil the seal of the new filter, tighten and you are done ......
    Jun 2010
    seattle
    Thanks for you help! I will try tonight!! thanks again!
    Jun 2010
    seattle
    Found it!!! now just need to get that strap for the removal!
    thanks again!
    PWCToday Regular almost_there6's Avatar
    Aug 2009
    Treasure Coast
    if you get the oil filter socket from Yamaha its very easy to remove
    '92 SN
    '98 GP760
    '94 WB1
    Top Dog volltrex's Avatar
    Sep 2006
    Jersey C I
    Quote Originally Posted by almost_there6 View Post
    +1.........Also always torque the filter up.......so many get over tightened & then are difficult to remove. Torque is 17 Nm.......can't remember what that is in old money
    Dave
    2007 FXHO 160 Cruiser, Sold
    2012 FXHO Cruiser
    North Alabama
    17Nm is about 12.5 ft/lbs I do mine like I do my car, hand tight + 1/4 turn.
    FWIW I use a strap wrench.
