SBT engine reliability? - Page 3
Results 21 to 30 of 47
    Sep 2007
    Toronto
    Re: SBT engine reliability?
    Quote Originally Posted by jeremyholmes View Post
    I wouldn't run an SBT engine if it were free!!! They are pure garbage. I will gladly post some pics of the guts of a few SBT builds. They use chinese parts or cheap parts, the pistons, clips, rings and sleeves are very weak. They sleeve many applications cause its cheaper than repairing factory style nikasil linings in the cylinder jugs, they don't check the run out too well on cranks and will send them out the door out of spec. Their sleeves don't even match the ports most of the time. I have alot of SBT engine pics if you guys have some, I'd like to trade with you, I don't want my customers on their junk and stuck in the ocean somewhere. No Thanks.
    Really? Please send us some pics.
    Fast, Reliable, Cheap - Pick 2
    Frequent Poster Ninetok's Avatar
    Sep 2010
    Wendell, NC
    By the way most bearings made now are foreign.
    21 years NC National Guard Tank Mechanic, Electronics Repairer, Tow Missile Repairer
    1997 GTX Bored 83mm microtouch rev limiter coffman ehxaust.
    1993 SPX Factory Engine never touched Microtouch rev limiter Pro Tec ride plate.
    1992 Polairs SL750 K&N air filter Jetted carbs.
    PWCToday Regular GSXRchris85's Avatar
    May 2009
    Ft Lauderdale
    i have a sbt yamaha 760 engine. i didnt buy it new. i got it with no time on it from the previous owner that gave up on his ski when the pump liner seized the impeller.
    i have never had a problem with my sbt 760 and i have had it for 2 years now, running strong. also rebuilt my pump with an sbt parts and an sbt impeller. good stuff.
    Jun 2004
    DFW- Texas
    Quote Originally Posted by Blackhawk36 View Post
    Jeremy, How can you feel so strongly that you are right when you are surrounded by authoritative professionals that don't agree with you! You are lone voice in the wilderness.
    I dont think he is the only voice, but as in the past, anyone who bashes these engines on here get a nasty PM from the admin or get banned. It makes the people that have issues with them not want to say anything, at least on this site.
    16 RXP-X 300
    JS 550 with 650 Conversion
    04 RXP - w/mods - SOLD
    99 GSX Limited #1- SOLD
    99 GSX Limited #2- SOLD
    96 XP- SOLD
    95 XP- SOLD
    94 750sx- w/mods- SOLD
    94 SN Superjet- w/mods- SOLD
    04 Speedster 200 -SOLD
    PWCToday.com Is My Home Away From Home Minnetonka4me's Avatar
    May 2002
    Minnetonka 'I'm on Big Island I3itch!!!'
    They usually do NOT ban people as long as they are civil about their complaints and can back them up. The admin here is much more willing to listen to complaints then other site IMO.
    Its been argued to death if its worth it...in some cases it is, and in some cases it isnt. We all know they dont use top quality parts...and unless you specify to your engine builder, he is prob using alot of the same parts as SBT.
    In a lot of cases...its the users fault in the first place...which they cover! Not many builders do...
    Nick @ www.WestsidePowersports.com -your Seadoo specialists!!
    Current machines being parted out -=click below for pictures=- PM for availability & pricing
    Mar 2007
    USA
    I have SBT engine since 2007 and still run good now.I bought and trusted SBT engine through some one did use it and recommend me. Also, NO FAULT warranty.
    IMO, if some one build something to sell and say NO FAULT warranty. That means they really know what are they doing to keep their business.
    I dream skis chev-hell's Avatar
    Ft.Worth, Texas
    I know this is an old thread, but I have been installing SBT engines now for around 5 years.... I've only had 2 bad ones from the get-go (1 yamaha 1200pv that the cases were welded and it leaked) and 2nd 4 stroke seadoo that who knows why it went bad.. both were replaced with no problem, and over the 5 years I have seen less than 3 total failures.... I spend at least 25k/yr. with them and about the only thing I don't like is the carb kits and the starters... everything else is great.... I'm currently running a 4 yr old sbt engine in my 96xp with a spec 1 pipe turning 7300... Shipping is a bit high, but all-in-all I am very pleased and I call them for most any part I need... so, take it for what it's worth but when I blow up this 787, I will buy another from them for my own ski...
    Krenn Power Sports
    707 North Fwy. Ste. 107
    Ft.Worth,Tx 76102
    Krennpowersports@gmail.com
    PWCToday Guru woodsrider40's Avatar
    Jul 2010
    Clinton TN
    I used SBT engines for years and not had one issues
  9. #29
    PWCToday Guru ImpactSportsTV's Avatar
    Jul 2003
    San Clemente, CA
    I know for a 100% fact that the statement above is B.S.- I have personally witnessed their crank tech true crank after crank after crank to within .001" on multiple occasions over several years. He simply wasn't satisfied until it was within .001" - and they didn't know I was watching them work, so it wasn't a show.
  10. #30
    PWCToday Regular jersey powersports's Avatar
    Mar 2011
    south jersey
    There is nothing better about an OEM Engine from a SBT engine. if the OE engine was so good they would not be getting replaced . I use to work at the dealerships many factory new engines blow up and get replaced under warranty. I have seen 100s of OE cranks fail { that were not customer faults} If the Engine is installed right and the problem that caused the first Engine to fail is fixed then a SBT or a owner rebuilt Engine will last.
    Jersey Power Sports
    609-435-0165
    Service on all Personal Water Craft and Jet Boats
    Most other Boats also
    over 25 years of Friendly Service
