Mr bojangles Truck Bed Ski Launch System........
» Hydro-Turf
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
    Resident Guru Mr Bojangles's Avatar
    Aug 2009
    Brevard County Florida
    Ok, I seem to be re posting this a few times a month, so I am going to make a thread about it so I can just link back to it instead of retyping every time, I know I am lazy!
    Ok, This is what I have made, its a system to launch your ski out of the bed of your truck by yourself. I decided to go this route because I didn't have a trailer at the time, and I also tow my boat, so for me to be able to take both, I made this. Now, for every truck and ski, there will be some different ways to do it, but the biggest part is making sure the rails stay in the bed of the truck! I used bolts, but whatever you use, it needs to work. I did modify some things for my 550SX, but it works the same. Also I can take full credit since others have made them too, some much nicer than mine, but here is mine...........................
    The system is made up of 3 parts, the ramp, the rails, and the winch. And the pictures speak for themselves, but I will add a few things.
    The ramp is simple, it is just 2x4's with wheels! I got them at home depot and they a 2" wheels. The reason for wheels is you have a steep angle to the bed of the truck, and with a winch, getting it up can be tough, so the wheels make it a cinch. The ramp is 8 feet long, and I added a 1 foot leg to the end, this is so when you launch it, the ride plate doesn't hit the bottom.
    The rail system is as wide as needed, I made mine 15" wide, and as long as the bed of the truck and tailgate. I also angles the ends to make it easier. I decided to use PVC for the bunks because I had some 2 inch and I cut in to fit, and used a heat gun to bend it. The only thing holding it to the bed of the truck are 2 anchor bolts from home depot that are called bed bolts (http://www.bedbolts.com/products-page/) I just got longer eye bolts and used them threw the 2x4's.
    Next is the winch, I just made a space in the rail system to hold a 4x4 post that I mounted a standard winch to, all it does is slide in, and then it has a eye bolt that I run a ratchet strap threw, and to the eye bolts in the bed bolts, so that when you are winching, it wont try and pull the winch post out, and then the ski is in, I can take it out and slide the ski further forward if needed. But if you can mount the winch to the bed, and not care about drilling holes, its much easier.
    When I use it with my 750 SS (~600lbs) all I did to launch it after I got used to it was attached a rope to the bow, and I set the ramp in between the rails, and push it off. I can be in the water in 2 min max, just as long as anyone with a boat. To pick up the ski, its just undo the winch line, then winch it up! It take a bit to pull in 16 feet of cable, but it happens quick.
    Video of it in action!
    http://www.youtube.com/watch?v=S6AQdWzzoKU
    Now onto the pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    1989 Kawasaki X2
    2005 Yamaha XLT1200
    2008 Water Craft Factory hull
    Truck Bed Launch System - http://www.pwctoday.com/f26/mr-bojan...ml#post2683099
    PWCToday.com Is My Home Away From Home fastlife23's Avatar
    Downtown Chicago
    Re: Mr bojangles Truck Bed Ski Launch System........
    mr b pretty innovative man!!!
    88 kawasaki Ocean Pro 650sx http://www.pwctoday.com/showthread.php?t=199374For Saleat SkeTech in Des Plaines great shop!!!! (847-699-0363)
    95 Blaster
    03 Shadow two place trailer
    evatime you see me post in yo thread I say Snapperrrrrrrrrrrrrrrrrrrrrrrrrrr, you can damn well bet yo threads in the crappeerrrrrrrrrrrrrrrrrrrrrrrrrrr,
    Feb 2010
    hiawassee, ga
    sweet i want one
    Top Dog madman2021's Avatar
    Nov 2008
    Kenner louisiana
    That was exactly what I was looking for.
    1982 Wetbike
    1989 Kaw jetmate 750SP
    1989 Kaw 650sx stocker
    1990 Kaw x2 750SP(bored801)
    1991 Kaw 650sx stocker
    1995 Kaw super chicken 750SP
    2004 Seadoo 150 sportster 4TEC
    2007 Yamaha FX HO
    2009 Yamaha vx deluxe
    2005 Yamaha sx230HO
    2002 Ford excursion 7.3 diesel dyno 412HP/739TQ"Fixed steer for life!! Only homos ride poles"
    The German PWCToday.com Is My Home Away From Home chantra's Avatar
    Jan 2007
    Sarasota, FL
    Wow...excellent work...looks amazing!!
    My respect!
    I dream skis codybrown's Avatar
    Mar 2007
    West MI
    How much do you estimate you have into it?
    2x 1990 550SX
    2001 Superjet
    2003 Superjet
    2015 Backie Chan
    1995 Seadoo SP
    PWCToday.com Is My Home Away From Home vshockey10's Avatar
    Jan 2007
    Midwest
    looks kinda how my snowmobile trailer is set up for skis now.. yours is a great alternative to the other ones that similar according to youtube on there lol
    Aug 2009
    Well the winch was $30 with a 30 foot SS cable, the wheels were the next at $2 a wheel, and the bed bolts are $13. I had the PVC and wood, so that's all I have into it realy. So it's not to much
    1989 Kawasaki X2
    2005 Yamaha XLT1200
    Frequent Poster 1991Kawa650's Avatar
    Jul 2009
    Canton, Michigan
    Nice setup man. I just carpeted the bed of my ram and just slide the standup in and out of the bed haha. i can imagine that wouldn't work to well with a sit down haha. good job.
    "Respond intelligently even to unintelligent treatment."
    - Lao Tzu
    Carbon Bob Gen 1, XS 1000
    PWCToday.com Is My Home Away From Home Offroadie's Avatar
    Aug 2009
    Permanent Vacation
    Quote Originally Posted by madman2021 View Post
    You're welcome.
    Quote Originally Posted by momarski View Post
    I am the one not displaying intelligence
    Quote Originally Posted by thajeffski View Post
    I'm the one here ruining the place.
    Quote Originally Posted by lakehoon View Post
    I'm local retard
    If you can't laugh @ yourself... call me.
    I'll laugh @ you!
