Results 1 to 10 of 12
    Oct 2006
    Boca Raton, FL
    SXR - how do I keep water out?
    I have an 06 sxr that seems to fill up with water whenever i attempt subs. I have a rule 500 pump in it that is always on and I have the PWC Doctor drain. After popping up from a quick sub I have too much water in it and it gets in the carbs. The hood seal is perfect, so I assume I need the air block off kit (or duct tape). Is there anything else I need to do to get air into the ski if I use the air block off? Any other thoughts on what to do?
    thanks,
    Eric
    PWCToday Guru superjetjames's Avatar
    Mar 2008
    Bellair Beach Fl
    Re: SXR - how do I keep water out?
    More Pumps..Quit subbing or buy a SuperJet.
    2010 Region 9 Exp Ski Ltd Champion
    2011 Region 9 Exp Ski Ltd Champion
    2011 Region 5 Int Ski Ltd Champion
    www.peakpowersports.net
    www.5starwraps.com
    www.rivaracing.com
    www.optimaracing.com
    www.dk1designs.com
    Wish I were 20 years younger!
    Banned SflSwampRat's Avatar
    Jun 2007
    making sure honduh riders get their fair share of shizz.
    Quote Originally Posted by superjetjames View Post
    that 'gets' the water out. he wants to keep it from coming in to begin with.
    or buy a SuperJet.
    PWCToday Regular turbovano360's Avatar
    Jul 2009
    Issaquah WA (lake sammamish)
    Make sure the little ball on your drain doesnt have any crap around it ( zip ties, weeds, wires, dirt)...I put a little wire mesh behind it and it works great, once in a while i will stick a garden hose from the outside of the drain plug blast it to blow dirt away...
    Get the air block off kit from blowsion, helps a lot and very easy to install...also make sure you are closing your hood the right way...sometimes it sits funny.
    Do you have any hood mods? or is it bone stock? Where is your bildge outlet located?
    2008 SX-R 800
    2001 Doo GTX
    2009 DRZ400SM
    2007 Warrior 1700
    PWCToday.com Is My Home Away From Home mmille_mr2's Avatar
    Sep 2008
    Washington
    Quote Originally Posted by turbovano360 View Post
    x2....works wonders. I don't even have a bildge pump on mine and i can do subs and fountains all day. You can cut another intake in the rear of your hood (per blowsion instructions) to help the recover airflow lost from the front intake.
    Mike Miller
    90 550/650 - Silver 650, 17 scat, SBN44, pipe mod - SOLD
    97 Daytona 1000 - almost mint condition, stock - SOLD
    1975 Jetstar boat with 115hp merc
    07 SXR - Bone stock, and staying that way!
    94 WB1 - Stock, Surf Ski
    Custom RN SJ - Mason Waddle Tribute Ski
    Jul 2009
    Quote Originally Posted by mmille_mr2 View Post
    yeah I made a cut out in the back right corner of the hood... I don't know if it helps with air or not but it doesn't let much water in
    2008 SX-R 800
    2001 Doo GTX
    2009 DRZ400SM
    2007 Warrior 1700
    Sep 2008
    Washington
    exactly what i did also
    Mike Miller
    Oct 2006
    Boca Raton, FL
    thanks for the replies. Anyone have a pic of the cutout they made after blocking the front one?
    Jul 2009
    Quote Originally Posted by heatz View Post
    Yeah I can post one later when i get home
    2008 SX-R 800
    2001 Doo GTX
    2009 DRZ400SM
    2007 Warrior 1700
    Sep 2008
    Washington
    if you turn the hood upside down one side has a molded in hole in the back(closest to the latch). The other side is filled. take a dremmel with a cutting wheel and cut the hole out. Easy as pie!
    Mike Miller
