    Jun 2009
    green bay,wi
    Running jet ski out of the water
    i have a 78 JS440 and she needs a little bit of work done to her, im in the process of trying to get it to start, itll turn over but wont start fully. I was just wondering if i can connect my garden hose up to the cooling hose and let the water run while i try and start it. cuz i know your not supose to run them out of the water for more than 10-15 sec.
    resident guru Jet1100STX's Avatar
    Jul 2007
    Laurel,MD
    Re: Running jet ski out of the water
    Don't run the water till the ski starts. You don't want it to backflow into the engine.
    99 Kawasaki 1100 STX
    96 Kawasaki 1100 ZXi
    Solas impeller, Ocean Pro rideplate, WORX intake grate, TDR Waterbox, Twist Sponsons
    87 Kawasaki X2- in progress JetSport Flame arrester,Mikuni 44bn carb, JetSport intake, Rear exit Exhaust, WC bilge bracket, WC oversize fuel tank w/ WC pick up,Coffman Exhaust,West Coast Intake Grate, PJS Ride Plate, Quickturn, Hood mod
    PWCToday Regular almost_there6's Avatar
    Aug 2009
    Treasure Coast
    No don't hook up water to the ski unless the motor is running.
    '92 SN
    '98 GP760
    '94 WB1
    Jun 2009
    green bay,wi
    k..thanks
    Spongebob PWCToday.com Is My Home Away From Home attnondeck's Avatar
    Sep 2008
    Youngstown NY
    just run it till it gets hot then let it cool. dont over heat it! you can run it out of the water for short periods of time.
    Brendan
    1990 SN SJ 701 1990 SN Super Jet 650 Winter build
    1990 550SX
    1990 300SX
    Jul 2003
    Pearland, TX
    Dont worry about the hose if you are just getting it to fire and shutting it down. If you can fire it and shut it down and then repeat, you know you got the thing running. Your next move is to tune it and thats not a hose operation. I personally like to only use the hose for flushing the system (saltwater brine). Otherwise, all tuning and testing is done at the lake especially if you are keeping the motor running for more than a few seconds.
    701 Square - with all the goodies
    I dream skis GasIt440JS's Avatar
    Jan 2010
    Old rule of thumb 15 & 15
    Run it for 15 seconds
    Let it cool for 15 minutes
    1982 JS 440: Kerker pipe, OP ride plate
    1989 JS 440 Hull: PJS Viper 7000
    1990 X2 650 the new kid on the block
    1992 Kawi Sport Cruiser 650 [The Build]
