Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Jan 2010
    California
    Has anyone converted a utility trailer into a ski trailer?
    Alright guys Ive been considering getting maybe a 5x8? and possibly putting enough bunks to fit two stand ups. I realize Id have to get submergeable lights and stuff. Would this type of trailer rust easier or what? Is it big enough to fit a 750 and a superjet? The reason im considering doing this is because 5x8's go for pretty cheap, and I could use it to haul dirtbikes and other stuff too and not only be limited to jetskis. If youve done this post pics.
    PWCToday.com Is My Home Away From Home bkoche's Avatar
    Jul 2009
    Centerport NY/Downers Grove IL
    Re: Has anyone converted a utility trailer into a ski trailer?
    Thats what I use. Id never back it into the water though. Trailers for the water are all galvanized and are more corrosion resistant than the just painted utility ones
    2004 SXR - FPP Wetpipe, Blowsion railcaps, 4deg bars, billet clamps
    1994 750sx - Loaded -FOR SALE
    1983 JS550 - WC RC520 reed cylinder, WC Head, PJS WB, Dual 38SBNs, WC 750 reed stuffers, WC Stacks, WC 6.5gal tank, FPP Halfpipe, SBT High torque starter, 16.5 Skat, Blueprinted 440 pump, lightened driveshaft, 76mm OP nozzle, Jetsport bulkhead brace, 90wt mod, WC scoop, Rend plate, Rear exhaust, Carbon Fiber
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    Jan 2010
    California
    How do you keep them tied down? Just using tie downs or ratchets??? Maybe I can use the trailer to get them there then use a beach cart to get them into the water or something.
    Jul 2009
    Ratchets. The deck has plywood over it which I screwed 2x4s to to keep it aligned side to side. I do the same thing to make a groove for my motorcycle tires when I use it for the bikes. Next upgrade is going to be making a form fitting cradle for the ski using the "Great Stuff" chair concept
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    Jan 2010
    California
    Maybe ill do that, and add a chock or two for the bikes. Seems like pwc trailers are rediculously over priced and regular utility trailers are pretty cheap.
    Jul 2009
    ya its not bad when you have stand ups that 2 people can carry down the ramp. your in a bit more trouble if you have a 900Lb couch
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    Jan 2010
    California
    Yeah but idk I dont want to have to be dependant on someone else to help me carry if their not strong enough or something. Ive been looking for another ski with a trailer...found a superjet (squarenose) and a trailer asked the guy how much and he said 2400!?!?!?! I was shocked.
    edit: heaviest itll be is a kawi 750sxi
    Jul 2009
    Ya, the first time I took my 550 out my gf slipped on the ramp and dropped it on her ankle. I cant afford a real ski trailer
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    Mar 2007
    Is Everything!
    Quote Originally Posted by txmxer View Post
    I have 2 double stand up trailers I want to sell. $300 for one, its in good shape and will need the second set of bunk installed. The brakets/harware is all there. All you need is 2 2x4s and some carpet, The other is $450 and in great condition with new paint and lights for the other. Where are you located?
    Jul 2009
    Too bad were as far away as possible from each other or I would take the $300 trailer
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
