300sx mods? - Page 7
Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: 300sx mods?
  1. #61
    PWCToday.com Is My Home Away From Home Laserman's Avatar
    Apr 2006
    Orlando, FL 32817
    Re: 300sx mods?
    I'm pretty sure I won't be needing it....
    Did I ever mention that I'm from NY? Just outside Syracuse.
    (Now I'm covered if I need someone up there killed......)
    1985 JS 550/750 Stand-up: http://www.pwctoday.com/f72/smileys-...50-114680.html
    1984 JS550 TYPHOON 750 conversion: http://www.pwctoday.com/f72/laserman...ct-186297.html
    1992 Sport Cruiser "Sportscar" Conversion: http://www.pwctoday.com/f72/laserman...-a-173049.html
    Here's a helpfull thread on 550\650 conversions: http://www.pwctoday.com/f72/just-ano...on-133898.html
  2. #62
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Re: 300sx mods?
    I've heard that there is a 500cc head that will bolt straight up the the 300sx bottom end. Any ideas on this?
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
  3. #63
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: 300sx mods?
    Quote Originally Posted by sportsfreak29 View Post
    Ive never seen one. There were some ramblings about using a KX500 cylinder but that wouldnt work without a LOT of work. Cases would have to be bored, base studs re-arranged, that is if the cases are even large enough. The crank would have to be stroked like 20 some mm. No way to operate the power valves, and having owned a KX500 the power is too peaky and without enough torque for watercraft use, and once you loose the powervalve its even worse. Then you have the issue of the 300 starter clutch that is already weak and probably wouldnt last a day with the larger cylinder. Would also have to block off the crankcase intake. And lots of other crap like an exhaust, cooling routing, etc. Better off sticking a 550 in it.
    -95 750SXI
    -90 TS650
    -91 300SX
