Connected Battery Cables wrong Please Help
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Apr 2009
    Boulder City
    So I have a 1996 Seadoo Xp 787 and I had the battery out of it for the winter to keep on trickle charge. Today was a nice day and i was considering maybe taking it out so I put the battery fully charged back in. Well it was hard to see down in there and i had left the cables in the same format they were hooked up before so i connected the battery cables up and put the key in no beeps or anything. So i got my head in there and Realized the cables were connected backwards. So i hurried and unconnected and connected the right way Red-Positive, Black-Neg. and put the key in no beeps or cranking, so i came on here and some folks said the fuse could be blown on the MPEM. Took the lid off and the one Five amp fuse on the Mpem was blown, and the other 15amp was good SO i replaced the Fifve amp with a new one and still no beeping or cranking?? Now im stumped is the MPEM Fried no wires or anything anywhere look smoked???
    Aug 2009
    nj
    Re: Connected Battery Cables wrong Please Help
    did you hook up the thinner black cable to the negative battery post? it easily gets lost in the hull.
    Jun 2008
    Glendora California
    You have blown an internal part inside the MPEM and now you need a new MPEM.
    Apr 2009
    Boulder City
    ok so its def. the MPEM then? And yes i did get that little black negative on there still have nothin, any place where i can find an MPEM? can you still order them direct from seadoo?? Also if i get a new mpem does it need to be programmed or anything by the seadoo dealer??
    Jan 2006
    Smoky Mountains TN
    I have a used mpem from a 96 GSX which was also a 787 if you confirm your mpem is bad. You would have to get the number off the silver tag on your mpem to confirm which you need. Yes if you replace the mpem you need to get the mpem programmed to match your dess key or you need to buy an mpem with a dess key.
    Before you spend any money you need to troubleshoot to confirm what is wrong. You can download a service manual at the link below. It will have ohm charts so you can test your components.
    http://seadoomanuals.net/manuals/1996-seadoo.php
    Resident Guru tweeker's Avatar
    Apr 2003
    Denver N.C
    the ignition coil in the rear box would be a place to start i'm sure if you look at it you will see a big crack in it
    1987 wetbike silverstreak
    1987 Yamaha exciter 570
    1988 wetbike silverstreak
    1989 x2 750 superstock
    1991 SC Piped 750
    1994 Kawasaki SC piped 750
    1996 Yamaha Vmaxx 600
    2005 SXR stock
    2006 SXR1100
    2006 grizzly 660
    2015 fzr sorta stock
    2015 FX SHO
    2016 FZR sorta stock
    Apr 2009
    Boulder City
    No no huge crack in it.
    Apr 2009
    Boulder City
    checked everything on MPEM with volt meter everything is getting power and all fuses are replaced and good still nothing
    PWCToday.com Is My Home Away From Home SeaDooSource's Avatar
    Sep 2006
    Ohio
    When you reverse the cables, that almost always kills the mpem. I have a used with programmed lanyard in stock if needed.
    OSD JetPump Rebuild Service here
    Heavy Duty RFI & DI Rectifier Upgrade here
    Everything you ever wanted to know about Mikuni carbs here
    Complete Single & Dual Carb Rebuild Kits with OEM Mikuni Parts here
    Apr 2009
    Boulder City
    ya what is a price on one? is it that whole grey box or just the mpem? im wondering if maybe it fried anything else in there to like the CDI or the rectifier or can they survive a reverse polarity
