Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Aug 2009
    Southern California
    Removing Flywheel
    Does anyone know how to remove the flywheel on an 86 js550. I took the cover off and got the bolt off, but the actual flywheel will not come off. I've pulled, twisted, and tapped it from behind with a hammer; with no avail. I read in my Clymers manual that you need a "Flywheel Puller" but in the past, it would just pull right off.
    Spongebob PWCToday.com Is My Home Away From Home attnondeck's Avatar
    Sep 2008
    Youngstown NY
    Re: Removing Flywheel
    need a fly wheel puller... you can get one at harbor freight for cheap. it shouldnt just "pull right off"
    Brendan
    1990 SN SJ 701 1990 SN Super Jet 650 Winter build
    1990 550SX
    1990 300SX
    Aug 2009
    Southern California
    I got a flywheel puller, but when i connected it on the flywheel i cranked it down and it isnt coming off. It cranks down to the point where it will spin the drive shaft... not sure what to do now. any thoughts?
    Sep 2008
    Youngstown NY
    i used an impact guy to tighten it really good. then smack the end of the puller with a hammer. it will pop off
    Brendan
    1990 550SX
    1990 300SX
    PWCToday.com Is My Home Away From Home Maulin Marto's Avatar
    Sep 2009
    IL.
    Try some propane, or map gas heat just around the base of the wheel....near where the crank is in the wheel. Don't heat the crank, the metal of the wheel, and not to long, maybe two minutes...then hit the tightened puller end with a dead blow or brass hammer. Also, it is critical that the puller is on 100% straight...that is a key to an easy pull.
    2010 UWP Masters National Champion, Governor's Cup / 2013 GLWC Masters #1/2013 GLWC Ski Slalom #1/2013 Vet Open #2
    2009 & 2010 Vet Open Great lakes Champion /2009 GLWC Masters #1 2009 Sport spec #1 /GLWC 2011 #3 Vet Open
    Ebay Store Link> http://stores.shop.ebay.com/Uncle-Martos-Parts-Store
    Aug 2009
    Southern California
    I have tightened the puller as far as it will go, and now tried hitting the end with the hammer. it is still stuck on there. would you suggest using like a propane torch? and heat what part of the flywheel?
    PWCToday Regular 750sxipro's Avatar
    Mar 2006
    Tampa
    stand the engine on end "flywheel up" remove your puller, heat the threads, then apply wax "cheap candle will do" sometimes this works like a charm. the wax will work into the threads and free them.....
    Sep 2008
    Youngstown NY
    threads on what?? the fly wheel isnt threaded on....
    Brendan
    1990 550SX
    1990 300SX
    Sep 2008
    Youngstown NY
    Quote Originally Posted by 86KAWIJS550 View Post
    what kind of flywheel puller are you using?? use shorter bolts to bolt it to the flywheel. that way you have more threads on the part that tightens the puller.
    you really shouldnt need heat. just a 5 lb sledge and use the puller correctly.
    Brendan
    1990 550SX
    1990 300SX
    Mar 2006
    Tampa
    Sorry, "The Shaft" you get the idea right?
