Results 1 to 6 of 6
    PWCToday Guru normjet's Avatar
    Aug 2004
    Down under
    sxr steering cable install
    I have a friend with an sxr who is complaining about the lack of steering, apparently the cable is slightly longer at one end than the other? is there a chance it is in the wrong way around? if so which end goes to the pump and vice versa.
    Thanks Norm.
    Top Dog RacerX2's Avatar
    Feb 2010
    Far Away From You
    Re: sxr steering cable install
    no I think that the bulkhead fitting at the pump cavity is different than the one at the handlebars I dont think its possible to do it backwards. You could have the wrong cable, it could be adjusted badly too.
    See di46 drink......See di46 drive......Don't be a di46......
    Aug 2004
    Down under
    It runs a umi pole actually so i wonder if he has a yamaha cable.
    PWCToday.com Is My Home Away From Home JasonZE's Avatar
    Jan 2004
    NewZealand
    if you put the wrong way round which is easy to do it wont go full lock one way and is near impossible to centre the nozzle when in wrong.
    I cant remember off hand which end is which but there is a bit of white tape on the outer which i think went to the handle bar end.
    More than likely he has it wrong find another ski and measure from the hull to the end of the outer at the pump to compare, my ski is at work so cant go measure it now.
    currently riding sxr or what ever has gas in it!!
    resident guru
    Dec 2004
    Mobile,Al
    Yes, same thing Jason said. We replaced the steering cables on 2 SXR's with UMI poles and the cable can go in backwards. It will connect up but will not turn fully in one direction. I cant remeber which way either though
    Father- what ever he isn't riding
    Son- Limited Class 03 SXR #891
    Freestyle 96 SJ
    Junior Ski Region 7 2005-2007
    Expert Ski Region 7 2008-2010
    PWCToday Guru ceebee187's Avatar
    May 2005
    gander, ks
    Seven years later...
    Just fyi for anyone else who taps this thread, the white tape goes to the front
    Sent from my C6730 using Tapatalk
