From the Honda Manual, here is a listing of the Honda codes.
Results 1 to 10 of 11
    Administrator Steph WCSS's Avatar
    Sep 2006
    Clearwater, FL
    2
    Never miss a good chance to shut up.
    www.shopsbt.com
    www.watercraftsuperstore.net
    Resident Guru J-Rod's Avatar
    May 2007
    Kingwood, TX (Houston)
    Re: From the Honda Manual, here is a listing of the Honda codes.
    Thanks Steph!
    PWCToday Guru RagingDiablo13's Avatar
    May 2007
    Racine/Wisconsin
    I must be slow.....I can not find where to put the jumper wire in to clear out the codes. I have printed the PDF and see where it should be, but can't find it....
    Neptune Racing
    Riva Racing Support Team
    Spy Optics
    Jet Pilot
    Six Feet Deep Clothing
    http://www.sfdclothing.com/familyboat.html
    http://www.greatlakeswatercross.com/
    IJSBA Novice # 2090032
    Top Dog
    Dec 2008
    Rock Hill, SC
    JR is correct but I think he meant to say 7-8 PSI and not 15 PSI to move the wastegate actuator. As for pulling the codes. Do the following.
    1. Ride the ski until it throws the code.
    2. Push the mode for 2 or more seconds to make it quit beeping.
    3. Then push the mode and set buttons at the same time for 5 or more seconds and it will start blinking out the codes.
    Make sure not to turn off the ski during this process or you might not get your codes. I would recommend pulling the code before doing anything else because it is so easy to do but I also think you may have a wastegate or solenoid problem.
    May 2011
    miami
    i have a prob with 03 aquatrax replaced plugs started ran fine 3 hours later wont start ,next morning low battery,while charging a hear a buzzing something is running by the battery while off ,when i took out the fuse for the starter relay it stopped ,would the relay keep it from havig spark???
    Jun 2003
    JACKSONVILLE FL.
    Quote Originally Posted by mark lurvey View Post
    The best place to post questions is in the forums below this, but your problem is probably a Main Relay which takes about an hour to change. The hardest part is getting the red wire disconnected from it. If you do a "Search" on this forum, you will get a boatload of information on the problem.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
    europe
    Quote Originally Posted by RagingDiablo13 View Post
    ...has this been answered somwhere ??
    PWCToday Regular Charlie Knapp's Avatar
    May 2010
    PA
    Finally time to put in new ECM I got last fall in my 03 turbo, to hopefully cure it from throwing f1 codes.
    Are there step by step instructions anywhere?
    Is it just unplug old and plug in new? Should I have battery disconnected?
    Sep 2006
    Texas
    my jetski is acting up and now i can figure out how to pull codes. thank you !!
    '04 F-12X
    '02 F-12
    PWCToday Newbie texas4play's Avatar
    Jun 2017
    Texas
    25 is my favorite .........eye roll please
