Results 1 to 9 of 9
    Apr 2006
    pa
    fuel return line restrictor
    i was told to use a #60 restrictor in my return line what do u use a #60 main jet in the return line this is new to me any help would be great thanks
    Top Dog Lakeside518's Avatar
    Jun 2007
    Clifton Park-Albany area, NY
    Re: fuel return line restrictor
    Yes you use a main jet as a restrictor. You can either use a quick disconnect restrictor Part# QD-14 or an inline restrictor Part#RY12-RLR-14 For reference check out http://www.hotproductsusa.com/PDFs/2009/2009_Intake.pdf
    I like to use the quick disconnect style fuel restrictor and I also usually run a #60 main jet for a restrictor.
    Scroll down about 1/2 way.
    Aug 2007
    Depending on what size you need welding tips fit nice in the line. They come in a few different sizes.
    Apr 2006
    pa
    thanks alot for the replys i was also told to use a #60. if its not to much to ask why the restrictor does the fuel actualy run thru that fast does it create a differant pressure on the pump or pop off pressure anyway thanks again this is a great site w/ a lot of good fun people
    Jun 2007
    Raises the fuel pressure and reduces chances of a lean out condition.
    I dream skis chriselmore_1's Avatar
    Sep 2009
    san jose ca
    what ski do you have? what carb? i used to run one in my 550 once upon a time
    SE MI
    These things are awesome and the least costly that I've found.
    http://www.oreillyauto.com/site/c/de...uum+restrictor
    Thanks to these companies for their great products and services.
    [QUOTE=Lakeside518;2561996]Yes you use a main jet as a restrictor. You can either use a quick disconnect restrictor Part# QD-14 or an inline restrictor Part#RY12-RLR-14 For reference check out http://www.hotproductsusa.com/PDFs/2009/2009_Intake.pdf
    i have the RY12-RLR-14's here in stock.
    just a FYI
    email watcon@watcon.com
    Please visit our web sites
    Sep 2009
    san jose ca
    are aftermarket mikunis restricted? or just the yamaha stockers...
