Results 1 to 8 of 8
    I dream skis engr146's Avatar
    Sep 2009
    Lynn.MA
    98 GP760 proper premix ratio
    I read some members suggest 32:1 some 40:1 some 50:1 What is the proper ratio,I will be using yamalube oil
    My tigershark 770 is 50:1
    98 Yamaha GP 760 (Newest)
    98 Tigershark 770TSL(sold)
    96 Montego DLX 640 (sold)
    33' Chriss Craft Catilina
    Jul 2009
    CT
    Re: 98 GP760 proper premix ratio
    Between 45:1 and 50:1 is fine
    PWCToday Guru 97gp1200's Avatar
    Jan 2010
    Kansas City
    I've always heard 40:1 for the best protection at WOT. Not the thread jack but what pre mix oil do yall reccomend? Looking for best bang for buck and also something that will work in my pre mixed Seadoo Spi.
    PWCToday.com Is My Home Away From Home ZMANN's Avatar
    Jan 2006
    AZ
    50 to 1 is the spec but I like 40 to 1 ,and I have had no issues
    http://www.pwctoday.com/image.php?type=sigpic&userid=15348&dateline=1238301767
    PWCToday.com Is My Home Away From Home tfergusonracing's Avatar
    Nov 2005
    Right in the lumberyard, Danny...
    I agree with Z. 50:1 is correct. I run mine around 45:1.
    It takes a big man to admit when he's wrong. I am not a big man.
    Sep 2009
    Lynn.MA
    sounds good !! 45-50 :1 It Is !! After my 1 st ski's oil pump causing a seizure ,both of my new to me ski's with be premix!!
    PWCToday.com Is My Home Away From Home MikePeavler's Avatar
    Mar 2005
    Anderson, Indiana
    OEM pump is 50:1
    If stock...I would run 50:1
    Modded I would run 40:1
    Crazy mod ...32:1
    Depends on power output....even at 40:1 you will notice more wear and the exhuast side if you ride it hard if your making good HP....Tim Judge has always said 32:1 with built engines
    M
    PWCToday Regular illtyler's Avatar
    May 2009
    rio vista, ca
    I blew my built ski on 40:1 so Im going with 32 or 36 :1. The ski clinic guys recommend 40:1. blowsion said no prob to go 32:1. I say just put a little oil in the gas and go!!
    96 rn sj freestyle setup
    88 sx
    99 gsx limited
