Just as the title says... can this head be saved?
750 PJS head damage... can it be re-cut?
Collapse
X
"needs carb work" is a classic excuse for I don't know wtf is wrong!
2009 EME Q8, 1100 ADA WB1 with MRD. 2004 BLOWSION RN SJ.
Big thanks to Newmiller Machine in Oregon for the great work! (Mcn6 on PWCtoday)Tags: None
Re: 750 PJS head damage... can it be re-cut?
I have a 650 that looks just as bad. I was wondering the same thing.RAD DUDES
www.RadDudesFI.com
www.Jetskiporn.com
How much of the piston was missing? A good welding shop should be able to fill in the deep gouges and reshape the damaged dome2004 SXR - FPP Wetpipe, Blowsion railcaps, 4deg bars, billet clamps
1994 750sx - Loaded -FOR SALE
1983 JS550 - WC RC520 reed cylinder, WC Head, PJS WB, Dual 38SBNs, WC 750 reed stuffers, WC Stacks, WC 6.5gal tank, FPP Halfpipe, SBT High torque starter, 16.5 Skat, Blueprinted 440 pump, lightened driveshaft, 76mm OP nozzle, Jetsport bulkhead brace, 90wt mod, WC scoop, Rend plate, Rear exhaust, Carbon Fiber
1991 Honda CB750
1976 Suzuki RE5A
1976 Suzuki GT750A
1975 Suzuki GT550M
Comment
If that were a stock head, I would say "no problem at all" to fix it via machining. We often get stock heads that look like this (and worse). After we do our standard milling and squish cut, 95% of the visable damage is removed. In some cases there are still a few remaining indentations, but they are of no concequence to performance or reliability. That machining mod normally runs $90.
All that said, there are some "aftermarket" heads that were cast with much less excess material to allow for that kind of repair (the Ocean Pro heads were the worst in this regard). PJS had more than one casting they used for their heads, so we would have to examine the casting to make sure it has enough casting mass to tolerate the machining repair.
Respectfully, Harry Klemm
Originally posted by 550/440 View PostJust as the title says... can this head be saved?Unless otherwise stated, responses to all forum posts are based on my personal experiences working within the PWC industry, and developing high performance PWCs since 1987.
www.groupk.com
Comment
OK, I have a stock head, would the stock head (after milling and squish cut) be as good as the PJS head in terms of performance?"needs carb work" is a classic excuse for I don't know wtf is wrong!
Comment
Comment
