Results 1 to 10 of 11
Thread: 98 GTX Limited
    Feb 2009
    South Africa
    98 GTX Limited
    Hi All
    My GTX Ltd started, to lag when it's pulling away in the water, but once it reaches top-end it runs fine. But when you leave the throttle, and suddenly give throttle again it has no power to pull away. It's if the ski has no power at low-end but runs fine at top-end.
    I'm no seedoo mechanic but I have a friend who is good with this sort of thing. He has serviced the ski for me, replaced plugs and did some general checks. Could it be the HT leads?
    At some stage the rpm dropped to 4000rpm and then jumped to 5500rpm and then it's if it got a boost to 6000rpm and runs about 80km/H
    Also the maintenance indicator is flashing on the electronic panel, could that be limiting the power? Also how do I reset the maintenance setting, without taking it to a dealer or is a special key or something required? ( Found the answer to this question on forum )
    The Show Me State - STL
    Re: 98 GTX Limited
    First thing that pops in my head when you are talking about power surges is the fuel system.
    Does it have the original gray fuel lines? If so you will want to look into replacing those with regular black fuel hose from an autoparts store and also cleaning/rebuilding your carbs.
    Re: 98 GTX Limited
    Have carbs cleaned/rebuilt & change out ALL fuel lines.
    PWCToday Regular jhjesse's Avatar
    Nov 2009
    georgia
    Re: 98 GTX Limited
    Quote Originally Posted by Water Worx View Post
    X2...and don't forget the fuel selector valve.
    Over analizing is common...simple answers are few.
    Come back to reality!!
    May 2008
    Wisconsin
    Re: 98 GTX Limited
    Your fuel selector may even have a small screw on it where you can pull the valve from the valve body to clean, unfortunately mine on a 99 gtx didn't, but definitely something to look for. All the above worked great.
    Top Dog wire4money's Avatar
    Aug 2008
    Central Oregon
    Re: 98 GTX Limited
    Check to make sure the accelerator pump is functioning correctly.
    Feb 2009
    South Africa
    Re: 98 GTX Limited
    Quote Originally Posted by wire4money View Post
    Please forgive me if this is a dumb question. How do I check the accelerator pump? Would it be in the shop manual?
    Re: 98 GTX Limited
    Accel pump is on the carbs,who ever does your carbs should know how it operates or they shouldnt be doing your carbs.
    Doo it once,doo it right.
    Jun 2008
    Glendora California
    Re: 98 GTX Limited
    The brass fuel accellerator fitting at the top of each carb, with the smaller grey hoses attached to them often get clogged up and need to be cleaned. So look down the bore of each carb as you work the accellerator pump lever, and see if both nozzels are squirting fuel.
    The surging problem sounds more like clogged filters in the carbs or a faulty water regulator valve on top of the muffler. Could possibly be from filthy sticking rave valve guiotines too. When was the last service done to clean the rave valves ?
    Feb 2009
    South Africa
    Re: 98 GTX Limited
    Quote Originally Posted by Mr. Bill View Post
    Thanks for the info Mr. Bill, actually we are planning to service the ski ourselves, hence the request for help. Money is a bit tight at the moment. I don't actuall remember when last this ski has been serviced since it was standing in storage for more than 2 years.
