Results 1 to 8 of 8
    PWCToday.com Is My Home Away From Home bkoche's Avatar
    Jul 2009
    Centerport NY/Downers Grove IL
    Impeller/Wear ring clearance/shimming
    How close should I have the impeller to the wear ring? Ive heard anything more than 10thousands/inch is too far away
    2004 SXR - FPP Wetpipe, Blowsion railcaps, 4deg bars, billet clamps
    1994 750sx - Loaded -FOR SALE
    1983 JS550 - WC RC520 reed cylinder, WC Head, PJS WB, Dual 38SBNs, WC 750 reed stuffers, WC Stacks, WC 6.5gal tank, FPP Halfpipe, SBT High torque starter, 16.5 Skat, Blueprinted 440 pump, lightened driveshaft, 76mm OP nozzle, Jetsport bulkhead brace, 90wt mod, WC scoop, Rend plate, Rear exhaust, Carbon Fiber
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
    PWCToday.com Is My Home Away From Home 10mm's Avatar
    Apr 2009
    MN
    Re: Impeller/Wear ring clearance/shimming
    As close as you can get it without touching. About the thickness of a playing card.
    Jan 2006
    Smoky Mountains TN
    Many manuals say 2 or 3MM is perfect and 6MM is too much, service limit, time to rebuild. For those of us who refuse to embrace that MM bullshyt that means 8 to 10 thou is perfect while 25 thou is the limit.
    Feb 2008
    New Zealand
    1mm is pretty much bang on 40 thou. So 2mm=80''' and 3mm=120'''. Think you missed out zeros donwkk?
    That would be an absolutely huge clearance, way more than the max you'd want to run. The closer you can get it the better the pump will perform
    Sometimes the same is different, but mostly it's the same
    Jan 2006
    Smoky Mountains TN
    Quote Originally Posted by tigermm View Post
    You are correct - I should have typed 0.2 to 0.4MM as factory spec and 0.6MM service limit. That equates to the 8 to 10 thou and 25 thou limit.
    Apr 2009
    MN
    Glad we got that cleared up.LOL
    PWCToday.com Is My Home Away From Home SJmullet's Avatar
    Sep 2004
    Sacramento
    Quote Originally Posted by donwkk View Post
    Good save :0)
    Jul 2009
    cool. thanks guys
    1991 Honda CB750
    1976 Suzuki RE5A
    1976 Suzuki GT750A
    1975 Suzuki GT550M
