I have a '99 Polaris SLH that i'm having problems with. Here's what it does.
I can unload it and it will start right up everytime. I can putt around on the lake at about 25mph and all is good. However, when i put the hammer down it will only run for about 8 seconds and then it dies. It doesn't slowly die, it just shuts off quick! It immediately starts back up. When you give it the gas, it always does this. And, after about 3 times of giving it the gas and it dying, it will not start at all. If you let it sit for about an hour it will then start back up again.
What could be the problem? Do you think it's not getting enough gas? It sounds as if it might be running out of gas? But why won't it start back up after the 3rd time or so?
It's got a brand new battery, the cylinders test perfect, and it has plenty of spart.
Any help would be greatly appreciated.
Comment
