Results 1 to 10 of 18
    Frequent Poster love-my-yama's Avatar
    Dec 2009
    Clearwater, FL
    starter works great but won't spin the flywheel
    1990 superjet - all stock
    I have removed the starter motor and she spins over freely but there isn't any hook-up when installed and given power... what is going on? Possibly the bendix? Usually they are connected to the end of the starter but not here? Need to know the next plan of action and any tips along the way. Thanks a bunch guys
    Boris asked to be MU'd...literally PWCToday.com Is My Home Away From Home Boris's Avatar
    Sep 2003
    Floriduh
    Re: starter works great but won't spin the flywheel
    The bendix is not connected to the starter on these things. The bendix is under the timing cover.
    Can you turn the motor over by hand ?
    Does the starter turn the motor over when the plugs are out ?
    What happens when you hit the magic green button ? Do you hear the starter spinning or is it all quiet ?
    Jan 2006
    Florida
    You will probably find the bendix is rusty and needing replacement.
    Go Gators
    Dec 2009
    Clearwater, FL
    Yep I can turn the motor over by hand as I have already taken off the head to have it milled (since this occured unfortunately). I have NOT turned it over by hand with the starter motor installed though. When I hit the greenie the starter spins over beautifully (installed AND holding in my hand).
    Pretty sure problem is just in front of the starter (terrible design, why?) I'm guessing that I'll have to go in through the flywheel? Is it easier to pull the motor or just the tank to work on her?
    thanks guys
    Go Gators David3aces!!!
    Dec 2009
    Clearwater, FL
    I will prob get to the cover tomorrow and give you all a further update...
    stand by
    May 2004
    Blowing up Motors
    Why is it a bad design?
    You'll need to take the flywheel cover off and remove the flywheel.
    The bendix likely needs replacement.
    Mar 2007
    Is Everything!
    I have good bendixs here should you determine you need one.
    Top Dog customride0105's Avatar
    Nov 2008
    sterling va
    prick is a good seller.. he can hook you up...
    also i have 2 heads one is a triton head puts u at 175 compression (85) or a riva girlled head needs domes (100)
    At least when my string hangs out I still ride...
    brad
    Dec 2009
    Clearwater, FL
    So I opened her up tonight and the bendix isn't as bad as I thought. I worked it by hand a couple times and it seemed to be fine so I reinstalled it and the starter (minus the flywheel) and gave them some juice and she worked great. Slid right forward as she should. Since only slight rust was starting to form I sanded it off and I'm letting her soak in mineral spirits overnight. Next is a bath in oil and then grease in the right areas and I'm gonna try it for now. I do need to replace the O-ring on the starter motor bc thats how I think water got in. Its only a matter of time before it gets stuck again. Hey PoM... how much for the bendix? zip code 32606 What years/models have this bendix gear for my 90 SJ anyways? Hey custom, is the only way to get that compression with an aftermarket head due to stock piston clearance so low that you cant mill the head much? thanks to all
    Nov 2008
    sterling va
    no you can mill the head. but yamaha has a common problem of cracking the cylinder on the intake side. so if your planning on doing mods reccomend a girdled head.
    brad
