Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 146
    Top Dog seajm's Avatar
    Oct 2007
    W. Palm Bch, FL
    701 raider waterbox mod.
    I was bored this week and decided to put a 701 Raider waterbox in the B1 and it was worth it! It is a definite improvement over the stock box. I have to admit that I was impressed with the results. There was a good added low end punch that continued through the mid range. I did not notice much with the top end, but who cares anyway. The pipe seems alot happier with this set up. Can't explain why, but I'm happy!!
    94 Blaster 1 701 KAPOOEY Under construction
    88 Kawi X2 w/ some goodies
    Sep 2008
    City of Blasters
    Re: 701 raider waterbox mod.
    Did you just use the stock blaster hose? Cut to fit.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Oct 2007
    W. Palm Bch, FL
    Quote Originally Posted by Yamabooeey View Post
    Actually, the hose from the pipe to the box is from the Raider. The hose from the box exit to the exhaust outlet is from the Blaster.
    Sep 2008
    City of Blasters
    Quote Originally Posted by seajm View Post
    Thanks, I think I'll give that a try. Does it sound a little different from the stocker?
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Oct 2007
    W. Palm Bch, FL
    Yea, there is a throatier sound. The big change is I was so used to listening to the sound of the motor and pipe in front of me, now it is behind me! Takes a bit of getting used to!! Make sure you get the small Raider waterbox there is a bigger one and good luck with the styrofoam it is a biotch to remove. I used a small torch and a old bread knife (thin and long). Then I had to use a a reamer bit on a drill where the knife would not reach. Makes a hell of a mess, so make sure you have a shop vac handy!!! Good luck!
    Sep 2008
    City of Blasters
    Cool, thanks for the info. I got some time off so time to hack it up. lol
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Oct 2007
    W. Palm Bch, FL
    Well, how did it go??
    Apr 2006
    Las Vegas
    Hey, just noticed this post, I've been doing the same mod, but with a limited factory pipe. I'll post up some pics when I'm done. My only problem now is I plan to switch to a mod pipe, so I'm gonna have to figure a new hose combo.
    Apr 2006
    Las Vegas
    So I got excited about this when I saw this post today and decided to bust out most of it tonight. Here is what I have, its about 95% done, just need to figure out where I want to put the hooks for the strap and what I want to stick underneath it for padding.
    I had the U pipe cut straight and flared so it would point straight back. Thats the stock blaster long hose, just cut it. Coming out the waterbox is the other stock waterbox hose. I bought the elbow piece at Pep boys for 4 bucks or something. They have a plethora of different exhaust tubing pieces to chose from.
    And the finishing touch is the rear exhaust. No more soot pump
    Sep 2008
    City of Blasters
    LOL, I thought I had some time off but, the phone started ringing. (so off to work I went)
    Well, now I'm gonna redo the motor and do the waterbox also. I'll post up some pics when I get to it. Hopefully, be finished by the 1st or 2nd week of January.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
