Results 1 to 9 of 9
    PWCToday Regular waytoofast's Avatar
    Jun 2008
    stockton CA
    hooked up battery wrong ( now no spark )
    ok i let me son hook up the battery today and i had someone here to buy it and now theres no spak ,, its been sitting for about 5 months now , so i don't know what to look for ,, its a 1991 650 sx ok thanks jon
    06 Yamaha 1100
    97 xp 800
    95 900 zxi
    01 saturn
    97 dakota 4x4
    1996 cbr 900 RR (OLD SCHOOL)
    May 2004
    Blowing up Motors
    Re: hooked up battery wrong ( now no spark )
    If there's a fuse, it may have blown from the reverse polarity.
    Jun 2008
    stockton CA
    i havent even checked yet , i wanted to get some ideas first plus its geting cold out LOL ,, thanks jon
    06 Yamaha 1100
    97 xp 800
    95 900 zxi
    01 saturn
    97 dakota 4x4
    resident guru lake-skater15's Avatar
    Sep 2008
    Modesto, CA
    I don't think that ski has any fuses. I don't know what would have gotten screwed up from reverse polerity in that ski but I know it has no fuses.
    No fuses on that ski and usually when you hook up the battery backwards you fry the ground wire running from the stator to the elect box.The problem is when it frys it melts itself to the wires next to it grounding them out as well,this sends the AC voltage from the stator straight to ground,just something you might want to check out.
    PWCToday.com Is My Home Away From Home 10mm's Avatar
    Apr 2009
    MN
    good info. Sounds like you speak from experience.
    Quote Originally Posted by 10mm View Post
    Well I have never personally done it but have repaired many for people that have.
    Apr 2009
    MN
    I did it for a second last season. Just a spark luckily no damage. Problem was I bought a thick red cable for my ground (they where out of black)
    Jun 2009
    michigain
    LOL I did it...1991 650sx. I am a shamed to say... I used a battery out of a polaris I think it was. It fit better backward's. It fried the wiring from the box with the starter soliniod to the stator... I wound up modifing a 650 ts stator and siloconed up the extra wire hole on the rubber gourment that passes through the case. They are not a direct bolt on from a ts. LOL how much for the ski... Good luck...
