Results 1 to 8 of 8
    PWCToday.com Is My Home Away From Home SJmullet's Avatar
    Sep 2004
    Sacramento
    FX1 and SJ factory B pipe interchangable??
    Will the superjet factory B pipe fit the FX1?
    I dream skis Squarenosed's Avatar
    Nov 2007
    Bonita, CA (so cal)
    Re: FX1 and SJ factory B pipe interchangable??
    It seems it will if you dent the chamber. Ask motoman96 about it...hah
    http://www.pwctoday.com/f23/blowsion...ke-249072.html
    My small fleet...[90 SN SJ ] [90 X2] [90 Jet-n-Cat ]
    Banned motoman96's Avatar
    Aug 2008
    Under a ROK....literally
    Lester, as long as you have a hammer handy you can make it work. If you need any help just call Blowsion, they will walk you thru the process.lol
    Sep 2004
    Sacramento
    LOL
    A hammer can make anything fit. Yes, I read your other post. Sounds like they were a lot of help...
    resident guru
    May 2007
    Minnesota
    Quote Originally Posted by SJmullet View Post
    only with a superjet gas tank
    PWCToday Newbie Jb90sx's Avatar
    Apr 2014
    Keystone Lake, Ok
    hammer and sj gas tank! watch your weld seem against the hull, and you have to massage the expansion chamber (hammer) right where goes over the left front engine mount, batt tray wont fit with the tank so I turned mine with the left rear mounting bolt still in stock bolt hole and drilled the two right bolt holes to match reinforced under the tray all fits with no rub! oh tank left rear rubber insulator strap mount wont work so I put a strap hook from a 550 in with a washer under and hood vent tubes you'll have to cut down just a heads up!
    Apr 2014
    Keystone Lake, Ok
    hahah just saw the dates on these posts hopefully figured out by now
    PWCToday.com Is My Home Away From Home Offroadie's Avatar
    Aug 2009
    Permanent Vacation
    They've had a few years to work it out!
    Quote Originally Posted by momarski View Post
    I am the one not displaying intelligence
    Quote Originally Posted by thajeffski View Post
    I'm the one here ruining the place.
    Quote Originally Posted by lakehoon View Post
    I'm local retard
    If you can't laugh @ yourself... call me.
    I'll laugh @ you!
