How to increase top speed
Results 1 to 10 of 19
    Oct 2009
    The South
    Is it possible to increase top speed without changing the impeller. I notice a lot of people on this site bragging about 550's hitting 45mph with an intake grate, ride plate, and bolt on pipe. I just don't see how this is possible unless you are turning more rpm's which would in turn burn out and overheat your engine. I believe 6500 rpm's is what you are looking for at WOT with a proper impeller set up. I'm not that familiar with this stuff so I was just curious how people are doing this and is it safe for the engine.
    Thank you for your input.
    Water:
    1988 X-2
    1988 650SX
    1989 650SX
    1990 650SX
    1987 650SX
    (3) 1986 JS300's
    1987 JS300
    1985 JS550
    1983 JS550 Team Butch Racing Ski... lots of Mods!!
    1992 Sea-Doo SP
    1978 JS440
    1986 JS440 (my first ski)
    ONE HOT GIRL
    Land:
    1997 RM125
    1992 LT250R Quadracer Modded to the Limit
    1986 RM125
    (2) 1987 LT230's
    2000 Yamaha Blaster
    2000 Yamaha Warrior
    2001 YZ80
    2003 KX 60
    1989 KX 250
    1990 KX 250
    ONE HOT GIRL
    Lots of projects in the works!!!
    Jul 2003
    Pearland, TX
    Re: How to increase top speed
    They didnt use a 14 year old kid on the world record stand up ski just for giggles. Im sure the smart ones will chime in for real advice but weight of the rider changes lots of things.
    Frequent Poster jetskijim's Avatar
    Mar 2008
    Orange Ca
    Want to go faster? Make more horsepower! You can get a 550 to spin much faster then 6500RPM, Some guys get them up to 10000, probably more, Higher compression, hotter spark, better fuel intake system, better shaped head domes, lighter components I.E. Flywheel, coupler, driveshaft, Performance exhaust, Watterbox, Ballanced & Welded crank, Cooler plugs, Better spark plug wires, Dual cooling (or bigger line) Porting, Porting, Porting, Hi compression head gasket, Higher octain fuel, Loosing ten pounds, Blueprint the pump, Change the Impeller ( Why wouldnt you its simple and cheap best mod for the money) will all help
    PWCToday.com Is My Home Away From Home 10mm's Avatar
    Apr 2009
    MN
    Quote Originally Posted by jetskijim View Post
    agreed
    PWCToday.com Is My Home Away From Home 550/440's Avatar
    Jan 2009
    Arizona!!!
    550s can get going pretty fast. The aforementioned pretty much sums it up. Get skinny, ride faster... add horsepower, ride faster... get more water through the pump with a good impeller, ride faster! Less water in your exhaust will help top end, there are lots of little "tricks" that can get you going faster, but the impeller is the heart of your performance...
    "needs carb work" is a classic excuse for I don't know wtf is wrong!
    2009 EME Q8, 1100 ADA WB1 with MRD. 2004 BLOWSION RN SJ.
    Big thanks to Newmiller Machine in Oregon for the great work! (Mcn6 on PWCtoday)
    I dream skis THUTCH's Avatar
    May 2006
    Midland Tx
    PM sent
    I forgot a few item on the mod ski..In my pm but you get the picture...
    550 will do 40-50 mph
    R5 Vintage Class 2nd Over all 2009 season
    R5 Vintage Class First Over all 2010 season
    Founder of TxH2oRacing July 2015
    TXH2ORACING Vintage Class First Over all 2016
    TXH2ORACING Vintage Class First Over all 2017
    I dream skis johnny5's Avatar
    Aug 2009
    Coldwater, Michigan
    loose weight!
    92 Yamaha VXR 650 Ocean Pro head, Ocean Pro Vortex flame arester, Twist sponsons, DG Quadra Fin aluminum ride plate, DG performance intake grate, Riva red pipe exhaust, DG aluminum water box, Solas impeller, UMI steering.
    Firm believer in "The Darwin Theory"
    "I don't feel tardy..."
    "Yamaha for life!"
    Spongebob PWCToday.com Is My Home Away From Home attnondeck's Avatar
    Sep 2008
    Youngstown NY
    oh!! thats it!!! dang ill take 3 of everything!!!!
    Brendan
    1990 SN SJ 701 1990 SN Super Jet 650 Winter build
    1990 550SX
    1994 FX1
    Mar 2008
    Orange Ca
    Yeah I've got all of that and a few more on mine, Runs really fast, I need to get it on radar or GPS soon,
    Banned motoman96's Avatar
    Aug 2008
    Under a ROK....literally
    you need to be turning WAY more than 6500 rpm's.
