stuffing a snowmobile motor in a jetski ?
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 112
    Top Dog js580's Avatar
    Aug 2008
    montana
    just wondering if it is possible to have it done ?
    Spongebob PWCToday.com Is My Home Away From Home attnondeck's Avatar
    Sep 2008
    Youngstown NY
    Re: stuffing a snowmobile motor in a jetski ?
    yeah why not. i have a 5500. its the same engine as my ski!
    Brendan
    1990 SN SJ 701 1990 SN Super Jet 650 Winter build
    1990 550SX
    1994 FX1
    Aug 2008
    montana
    well i was thinking of stuffing a polaris 800 twin with VES into a js 300 hull
    just not sure how i would start fab it up ... only issue is heat from exaust, aggragement on exaust
    and the coupler
    Sep 2008
    Youngstown NY
    if you got it jammed in there. it would probably melt your hull!!! how would you go from belt drive to direct to the shaft?
    Brendan
    1990 550SX
    1994 FX1
    Aug 2008
    montana
    well the clutch can be removed and will only show the tamper ..
    and do a custom coupler.. and slide it back on and bolt it in . i think you are right about the exaust .. how about what if you used a exaust wrap on the pipes would that work ?
    PWCToday.com Is My Home Away From Home JC545f's Avatar
    Jan 2002
    CA
    Quote Originally Posted by js580 View Post
    and the coupler
    Converting it to open loop cooling would be a heck of a challenge, but not impossible.
    Does Polaris have a water craft engine similar to that? If so, does the watercraft exhaust manifold bolt up?
    You would probably want to remove any clutches, and of course fab a PTO or coupling to the end of the crank.
    Personally, I would shoehorn in an existing water craft engine, it would cut down on fabrication a lot.
    Sep 2008
    Youngstown NY
    maybe... im willing that compartment would get super hot and hinder your intake though... and if exhaust leaks at all. sufficate the engine. it would take some hardcore fabricating to get this to work!! and did you think about cooling???
    Brendan
    1990 550SX
    1994 FX1
    Aug 2008
    montana
    well for the water cooling it has built in waterpump maybe route it as same way as you would on jetski but water will exit out of the exhaust ?? like a boat would ?
    Aug 2008
    montana
    i meant the water pump on the motor is already on it ..
    PWCToday.com Is My Home Away From Home ryanr's Avatar
    Aug 2009
    where the wild things are (central wis.)
    js, see what i mean. i knew you would get some input. everything we have talked about has come up. now we just have to do some fine tuning on fab work and getting a pump prime for cooling. may have to work out a pre-prime system before starting the motor but at least you wouldn't have to worry about back flooding the motor with water. or would you?
