Results 1 to 2 of 2
    Oct 2009
    Houston
    94 Waverunner 3 exhaust gasket installation question
    I have to replace the gasket between the cylinder and manifold and the surfaces are not perfect. I will run it in salt water so I want to keep whats left of the surfaces dry. Is there a gasket that has the silicone or some sort of sealer already impregnated on it that would help seal them? Is one brand gasket better for this than another? Can I use Permatex Spray Copper (good to 500 degrees) to aid in the seal or is there something better? I do not think the water sides of the surfaces will get hotter than 500 but am not sure about the area right around the exhaust ports.
    Dec 2005
    Wisconsin
    5
    Re: 94 Waverunner 3 exhaust gasket installation question
    Are both surfaces real bad?
    If the mainfold is the main problem, I'd cosider replacing it, as used OEM ones are available very cheaply.
    I don't know of any gaskets or gasket "techniques" that do what you're asking. Flushing with freshwater after every ride is critical.
    WHEN IN DOUBT, GAS IT!
