Results 1 to 9 of 9
    Aug 2009
    SC
    Reading plugs on 2 stroke
    How do you read the plugs on a 2 stroke? I have a recently rebuilt (pistons, rings, rebored cylinders) 94 Montego with a 640 engine. The mag side plug is dry and the pto side is wet. Which one is right? With a single carb how can they be different? Compression is still good (130 - 140 psi), but ski is bogging and won't take the throttle. Any ideas?
    Apr 2003
    Charlotte, NC
    Re: Reading plugs on 2 stroke
    If you have a single carb and it is clean and set to the same settings as it once ran well with then the carb may not be the problem. Could be a broke reed pedal from being hydro locked or a bad spark plug, plug boot or coil?
    http://www.pwctoday.com/f34/carb-tuning-62278.html
    Providing service to all model Ski's in the Charlotte, Lake Wylie area.
    I dream skis engr146's Avatar
    Sep 2009
    Lynn.MA
    Aug 2009
    SC
    engr146 - thanks for the great reference document. A great discussion on the theories of tuning 2 strokes. Being an engineer myself I can appreciate this kind of detail.
    dank - engine was running well before it started losing power. Ignition appears to be ok, but will try new plugs. Reeds are ok as well. I assume the plugs should be dry, not wet. Could it be a vacuum leak? I'll be pressure testing soon.
    Thanks.
    Mar 2007
    Is Everything!
    The plugs should be dry and a nice even toasty brown color.
    However to get a correct reading the motor must be operated under load and at high RPM then shut down. Reading plugs after running on the hose or idling in th driveway is not a accurate indication. With that being said in any case one should not be dry and the other wet.
    EDIT- Not the best chart but you get the idea
    Mar 2007
    Is Everything!
    http://images.google.com/imgres?imgu...%3Den%26sa%3DG
    I dream skis Krispy's Avatar
    Oct 2006
    LaGrange, GA
    Quote Originally Posted by engr146 View Post
    Great bit of reading! Thanks!
    PWCToday's first Tigershark owner Moderator
    lownrangr's Avatar
    Nov 2001
    I can hold up my hand and point to where I live. Can you?
    Yeah, good illustrations.
    I winterized my 1100R yesterday and i checked the plugs and damn, they are abso-freakin-lutely perfect. I love my motor.
    Region 6
    Shark Bait
    #713
    My race boats:
    1999 Tigershark 1100R (ret.)
    Novice 1200 Stock
    1996 XP
    800 Limited and 1000 Superstock
    2017 Achievements
    4th at World Finals Pro-Am 1100 Superstock
    5th at World Finals Am 1100 Superstock
    7th at World Finals Am 1100 Limited
    Thank you to my sponsors: GoPro, AMSOIL, Riva Racing, Incase, Shorai, ODI Grips, and Ryno Power.
    Check out my Facebook page: https://www.facebook.com/TripleLRacing/
    Sep 2009
    Lynn.MA
    THX ,for sample sheet,I'am a power plant engineer,I can rebuild a steam turbine,But I have a long way to go understanding 2 cycle engines and troubleshooting them,I have learned so much from this forum.and learn more everyday!!
    Quote Originally Posted by gizmoe107 View Post
    Thanks.
