Results 1 to 10 of 14
    PWCToday Regular GregE's Avatar
    Louisville
    winterizing VX110 and FXHO
    I hate to say it but it's time for me to winterize my waverunners. Any recommendations of where to get it done or should I just go to Yamaha of Louisville? Or is it something I could do myself? Love to be able to save some bucks but want to make sure it's done the correct way too.
    Greg
    2008 Yamaha VX Deluxe Eclipse Black
    2008 Yamaha FX Cruiser HO Platinum Metallic
    Frequent Poster reisenback's Avatar
    Nov 2006
    Louisville Ky
    Re: winterizing VX110 and FXHO
    do it your self no big deal. should tell you in your book what you should do
    06 15f
    07 Ulta250 (was a Proud New Owner) Sold this gas sucking boat
    07 15f
    Sea Ray 300 Sundancer
    Just another payment
    Guest
    I did my HO last Sunday and it took 1 hour and 15 min and cost a total of $60. The SEARCH button is your friend...learn how to do it yourself.
    Man of Steel PWCToday.com Is My Home Away From Home davidw's Avatar
    Feb 2007
    US of A
    why is everyone " fallerizing" their ski's already ?
    Louisville
    Quote Originally Posted by Just another payment View Post
    Been searching. Is it just a matter of fogging and sta-bil? Not sure where to spray the fog.
    Guest
    Quote Originally Posted by GregE View Post
    Yep!
    Fill it with gas… and put stabilizer in it.
    -Run it a bit with anti-freeze in it (normally the pink stuff made for aluminum engines)…. Run it until the antifreeze come out..
    -Fog the engine with oil (you buy special fogging oil… normally I pull the plugs and liberally spray it in each cylinder… turn motor over a few times (without plugs)…..
    -Disconnect the battery. Grease the coupler (should be a grease fitting towards the rear of the engine).
    Louisville
    Yep!
    So remove the plugs and stray the fogging oil in that way. Got it.
    How do you get the anti-freeze in? I know the flushout port but can you tell me the procedure you use to do it?
    Guest
    Hmm.. that's a good question. I put the antifreeze in my "Salt-A-Way" canister and ran it through the hose (same as if I was flushing it but with Antifreeze). I'm not sure the best way to do it otherwise maybe someone can chime in.
    Louisville
    I'm running in lakes so don't need salt-a-way. I did look it up and I guess I could just get the mixing unit. I take it that you use the mixing unit so your antifreeze is diluted.
    Sep 2007
    kentucky
    I charge 75bucks for the simple winterization feel free to call me
