Yamaha VX110 Overheat Warning Indicator - Page 2
Results 11 to 20 of 34
    Frequent Poster Lee Taylor's Avatar
    Sep 2013
    Charleston SC
    Re: Yamaha VX110 Overheat Warning Indicator
    Quote Originally Posted by hatchetman View Post
    I also checked to see if I had any trouble codes by pressing the dashboard button and I did not, it gave me a 01 which is normal.
    Which button or buttons do you depress? Do you hold them down or depress and release?
    I think mine swallowed some sand.
    Took 2 hours to get it free
    Seems like I would know better by now
    Owner. Rider. 17 years
    2002 Yamaha. FX140. MR-1, 1000cc. Cruiser
    2017 Lowes Stryker 16. Mercury 50hp 4-stroke
    Jan 2006
    Florida
    0906161244.jpgWater enters and drains at this pipe. Cylinder head also has passages that get clogged. See it all the time.
    Jan 2006
    Florida
    0804161014.jpg Crap gets almost as hard as tile grout. Seen this many times in my neck of the woods. Often it's packed right at the thermoswitch.
    Sep 2013
    Charleston SC
    I have been through this process with the salt accumulation and formation (thanks to an un-named household member who did not remember to flush....).
    Mine looked exactly like your photo. I will measure the Thermo Switches first. I want to take them out of the equation
    I had the head off and cleaned it well in 2015. I have since unintentionally plowed into a sand bar at high speed. (long story) Took hours to get it out.
    I may have the water jacket full of sand. The oil cooler may also be full
    Sep 2013
    Charleston SC
    OH YES I REMEMBER. I had to put down the screwdriver and pick up a dremel motor tool
    Sep 2013
    Charleston SC
    I would post photos but Photobucket (where I USE to store photos) has gotten weird. They now want $400 if you want to share your photos. Go figure. Goodbye Photobucket
    Sep 2013
    Charleston SC
    Going by memory, I seem to remember the cooling water inlet and outlet, on mine, being the two pipes coming out of the top of the valve cover
    Sep 2013
    Charleston SC
    Frankly I am hoping for a bad Thermo-switch because I sold my engine hoist... wouldn't you know it
    Jan 2020
    fl
    2
    Im having the same problem, Big problem is getting to the sensors to replace. Im not capable of pulling the engine. sounds like a big job.
    can you just leave sensors off ??
    Jan 2020
    fl
    2
    does anyone know what the engine temp should be after running for 10 minutes. 2010 Yamaha VX 1100 nothing in service manual
    also noting much on cooling system
