Results 1 to 10 of 13
Thread: Oil in hull.???
    May 2009
    clarksville
    Oil in hull.???
    Somewhat new to jet ski maintenance and need some advice. I bought this ski last year .... 1995 Kawasaki 750 XI. When I bought it the hull was very clean. I rode it 2 times and noticed a little oil in the hull. I looked at it a bit and noticed one of the oil lines was cracking and leaking. I took it to the shop and asked them to convert it to premix. I guess all they did was unhook the the oil pump lines and plug the carb in lets because the oil pump is still on the crank ( no block off plate). Now the problem.... I'm slowly getting more oil in the hull. Not running oil or even enough puddle but it's just a little very spread out. A friend told me that the "plug" on the bottom of the motor may be letting the oil out and the oil isn't getting into the motor as it's burning from the compbustion. The "plug" he is referring to is the one that is connected to the little punger thing on top of the motor that you can pull to release pressure from the bottom. I really don't know what it is. Does this sound right. How do you know if it is performing properly, do I need to release this valve every once in a while? Is this problably the problem?
    Thanks for the help.
    BOYD
    The Show Me State - STL
    Re: Oil in hull.???
    Boyd, I am not a kawasaki guru...but I have read enough to know that those drains are a common nuisance on those motors. You can buy(maybe even make) a block off kit for that which disables that feature. A problem is, if that is sticking open you could in theory be getting too much air which will cause you to run lean.
    From my understanding its basically just a way to drain your lower crank case in the event you get water in the motor. Or at least thats what would make sense to me...
    Jul 2009
    Breezy Point NY
    Re: Oil in hull.???
    I have the same ski with the same problem...not such a big deal but the draining method does suck...i guess ur happy u switched to premix before that cracked oil line really did it's $$$damage$$$
    Mar 2007
    Is Everything!
    Re: Oil in hull.???
    It is documented on this board ( I think by WB1994) on how to turn the existing CC drain set up into a block off. Also I have the flywheel cover block offs if you are interested.
    Apr 2009
    auckland , nz
    Re: Oil in hull.???
    open your flywheel cover and look if those guys actually grinded the front bit of oil pump..... and check if oil intakes in carbs were blocked..........dont trust anyone
    May 2009
    clarksville
    Re: Oil in hull.???
    Thanks for the help. I will look into those things.
    One other thing. The power trim doesn't work. What's the first couple things to look for on that?
    Apr 2009
    auckland , nz
    Re: Oil in hull.???
    open the box..........bet it is full of rust get it off....i mean the trim box.........U probably have to short circuit two wires to make it work.......and loose your dash
    Jul 2009
    Breezy Point NY
    Re: Oil in hull.???
    make sure the trim wire is connected to the negative side of the battery
    May 2009
    clarksville
    Re: Oil in hull.???
    Thanks guys. I'll check it this weekend when I go to the lake.
    I think I'll take some pics. Thanks again.
    I dream skis carlosburitica's Avatar
    Sep 2009
    fort lauderdale
    Re: Oil in hull.???
    block off plate.forst in the list, neew gasket for the magneto cover, second on list, remove the oil tank if still in there, trim box.????? i don't think but take a look. just to make this story short i had a similar problem and i found that i had a 1/4 gallon 2stroke oil container half open under the front storage box..
