Results 1 to 10 of 11
    PWCToday Guru jasen b's Avatar
    Aug 2009
    Highland, NY
    Rv antifreeze VS Automotive antifreeze
    Just a quick question about winterizing my 96 HX. What isthe prefered fluid to use for winterizing pwc's? I live in upstate ny and curious if RV antifreeze was ever used in pwc's. I know that the stuff used in RV's is for potable water systems but it sems to me that it would be a little friendlier to the enviroment. Any thoughts?
    PWCToday.com Is My Home Away From Home SeaDooSource's Avatar
    Sep 2006
    Ohio
    Re: Rv antifreeze VS Automotive antifreeze
    The operators manual actually calls for ethylene glycol with corrosion inhibitors but I never saw a need for that. I'm in Ohio and all I ever use is pure pink RV antifreeze with no problems even with the occasional below zero days.
    OSD JetPump Rebuild Service here
    Heavy Duty RFI & DI Rectifier Upgrade here
    Everything you ever wanted to know about Mikuni carbs here
    Complete Single & Dual Carb Rebuild Kits with OEM Mikuni Parts here
    Aug 2009
    Highland, NY
    Thanks, this what I was looking for. I didn't want to drop any more toxic antifreze in my yard or where ever I winterize...
    resident guru 1fastski's Avatar
    Sep 2002
    villas NJ
    pink is all you need , the green { car stuff} can get into the gaskets and make them soft and oily , besides killing marine life . if your in a salt area use some saltAway before putting the ski away for winter .
    i like to help people ,if you own a PWC you need help iam here
    WWW.1fastski.com
    Sep 2009
    Bismarck, ND
    My Sea-Doo dealership uses the environment friendly RV antifreeze (I live in Bismarck, ND)
    I dream skis needforspeed's Avatar
    Sep 2008
    New Jersey
    try windshield washer fluid it doesn't freez either and way cheaper
    If it aint broke...don't fix it!!!!
    Aug 2008
    Boise
    Quote Originally Posted by 1fastski View Post
    how can that be if the shop manual calls for it (not the normal car stuff, but with inhibitors for aluminum engines)?
    Quote Originally Posted by needforspeed View Post
    only if it has the anti freeze added to it, so you have to check the label. I've had the normal blue stuff freeze.
    Jerr
    SeaDoo FAQs
    Kawi FAQs
    88 JS550
    Sep 2006
    Ohio
    If you're leaving it set for years, you might want to use the more expensive antifreeze with corrosion inhibitors but most people only store for several months so I wouldn't think you need 'em for that amount of time.
    May 2007
    Canada
    I use pink stuff rated for -50 C ($3 per gallon) up here in Canada and store it outside where it routinely goes -25C without any issues.
    Feb 2002
    Vancouver, BC Canada
    Quote Originally Posted by bigi View Post
    LOL! Not in my part of Canada. You must be from down east.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
