Results 1 to 10 of 17
    Jun 2009
    South Florida
    Marvel Mystery oil added to gas.
    Has anyone ever added Marvel Mystery oil to their gas/oil mix.
    How much do you use per gallon?
    The Show Me State - STL
    Re: Marvel Mystery oil added to gas.
    Why? Whats your goal you wish to obtain by adding it?
    I know some people swear by that stuff...however I have heard its just a gimmick. What people don't realize is that when you go putting additives in your fuel, you are taking up space that is usually used by fuel...therefore making your fuel ratio lower which makes your ski run a bit leaner. Running lean= Detonation. Granted my example may be a bit exaggerated, its still a fact.
    resident guru jetski9010's Avatar
    Mar 2008
    Sacramento
    I always use it. It is great for trying to keep the inside of your motor cleaner. It says to mix 2oz per 10 gal but I usally double that.
    PWCToday.com Is My Home Away From Home tfergusonracing's Avatar
    Nov 2005
    Right in the lumberyard, Danny...
    How does it keep it cleaner?
    It takes a big man to admit when he's wrong. I am not a big man.
    Quote Originally Posted by tfergusonracing View Post
    Exactly what I was wondering. Im not saying the stuff is junk...but from everything I have heard from people that knew that they were talking about..its not worth it.
    Its not like 2 strokes have a ton of build up on them...I would be more worried about running good oil and gas..that way you don't have stuff get gummed up.
    PWCToday Regular tymeshare's Avatar
    Sep 2009
    St. Peters, Mo.
    Yeah...little lost with this..lol..
    MMO has its uses..but I have never heard of using it in a 2 stroke..
    I have freed siezed and rusted engines/lifters with it before..but they were all 4 strokers..
    Not saying it will hurt..but I dont know what it may help..
    76 JS400 (..where's my 650?)
    77 Ski-Wheee..WTF?...order parts from ?..
    76 JS400 (bored, shaved, new electronics...WAY better ski for the trouble..just needs a 16*implr)
    79 JS440 (donor..maybe a cooler soon)
    88 JS440 (hot water in my tray!)
    90 X2 (appearently...If the lord wanted it to have a 750..he'd a willed one in there..)
    PWCToday.com Is My Home Away From Home cameron da river rat's Avatar
    Jul 2003
    In the Garage.....
    it's got to be some type of detergent imho. it says to add it to crankcase oils, replacing an entire quart in a 5 quart system with it, add it to gas, diesel.................im pretty sure its a detergent of some sort. smells wintergreenish like ben*** to me. i've used it in all kinds of stuff but never long term to see any results. i had an ex racer say he use to stabilize fuel in the off season with it...............?
    there is a chemical engineer next to my shop and i asked him about it and he says its mostly karosene. said he can request an msd for it and have it made up.
    aka "Cameron Da River Rat"
    (jetskianist~addicionist~modificationist)
    www.jetski247.webs.com
    92 550sx 650 conversion sweet.........
    94 fx1 (under modification)
    2 X2's (under modification) one for the kiddo
    98 spx stock/fpp spec2 (broke)
    03 genesis i (huge pos)
    95 f150 tonka toy
    04 suby sti
    Frequent Poster shock720's Avatar
    Jul 2006
    toronto
    if your plan is to clean up the inside of your motor from the carbon and such go to your local airport and get a few galons of 100LL and burn that
    1985 kawasaki 550js
    1989 kawasaki 550js
    1989 PJS ProCircuit Kawasaki js
    1986 Butches racing js 550
    1989 Kawasaki js 300
    PWCToday.com Is My Home Away From Home professor9's Avatar
    Nov 2005
    Cranberry Township, PA
    I also would strongly suggest not using Marvel Mystery Oil in any two stroke engine.
    Our two stroke engines rely on two stroke oil for lubrication. It's atomized with the gasoline to lubricate, and adding another ingredient like Marvel upsets the recipe. In effect, Marvel may well lubricate, but may reduce the lubrication abilities of the regular two stroke oil in the process.
    I suggest what I always suggest - select a good oil - AND STAY WITH IT - and use the best gasoline you can find and always use the same oil to gas ratio.
    Count me in the camp of leaving the Marvel Mystery Oil on the shelf. Use it in your air compressor, not in your ski.
    One other item - two stroke engines stay very clean provided you keep water out of them.
    Prof
    84 550 Conversion, 650 Stroker, '86 X2 ignition, 19 Skat
    87 X2, Stocker, UMI, Drop Nozzle kit
    90 TS, Stocker, full Coffmans, full Ocean Pro, Keihin, screams
    95 750 SXi, impeller, ride plate and pole spring, otherwise stock
    Lots of 1986 X2 parts (parted out a few of them)
    "The 2nd Amendment is not for hunting. It is for government to be wary of an armed populace rising up against tyrannical government."
    Mar 2009
    michigan
    MMO holds a special spot on my shelf. I have used it 1 time, when I started a fresh top end. I didn't want anything to stick ( like rings ). squirted it right down in the plug holes. It does change the viscosity. It is a detergent additive. I don't use it . I would rather add another 1 of my old time favorites like " Sea Foam " and I do from time to time run it in all my machines. I have 2 cans of that on the shelf. You can even fog the motors with it.
