Results 1 to 10 of 14
    resident guru johnny5's Avatar
    Aug 2009
    Coldwater, Michigan
    Cleaning my jet ski
    I have a 92 vxr i am new to jet skis and was wondering how i should go about cleaning it i have had a boat for 2 years so i know the rules about gel coat fiberglass ect but my boat is a ob and jet skis.. well im worried about power washing the hull inside and out (or not) i dont want to ruin anything my bilge is kinda nasty and the aluminum could use a lil cleaning too any suggestions? thanks!
    "if i miss spell anything i dont care dont call me out on it unless you dont understand what i am saying thanks"
    May 2005
    Royal Oak, MI
    Re: Cleaning my jet ski
    92 VXR is probably SMC hull, with epoxy paint on top. You can powerwash the outside form a distance (away from stickers though). The inside you can rinse with plain water and soap and scrub.
    2001 Ultra 150
    2009 Superjet
    1994 FX1
    resident guru
    Feb 2009
    Miami, FL
    Same way you wash a car. Get a bucket, some car/boat soap that will not strip wax (unless you do not plan on waxing the hull - in which case use whatever soap you want), and a sponge. No need to pressure wash anything.
    Pressure washers are for sidewalks, tile roofs, and walls that need to be stripped of paint.
    PWCToday's first Tigershark owner Moderator
    lownrangr's Avatar
    Nov 2001
    I can hold up my hand and point to where I live. Can you?
    Quote Originally Posted by Iguana View Post
    and decks and patio furniture too!
    you can also get bilge cleaner if you want. It's supposed to degrease and clean. I've never tried it before but I have 2 bottles of it in the garage. I'll use it eventually.
    Region 6
    Shark Bait
    #713
    My race boats:
    1999 Tigershark 1100R (ret.)
    Novice 1200 Stock
    1996 XP
    800 Limited and 1000 Superstock
    2015 Achievements
    1st Place Overall 2 Stroke Limited on the CWA CanAm Tour
    7th Place at World Finals Am R/A 1000 SS
    7th Place at World Finals Pro-Am 1000 SS
    Thank you to my sponsors: GoPro, AMSOIL, Riva Racing, Incase, Shorai, ODI Grips, and Ryno Power.
    Check out my Facebook page: https://www.facebook.com/TripleLRacing/
    Fixin' To Get Slapped PWCToday.com Is My Home Away From Home skraggy's Avatar
    May 2005
    St.Pete FL
    For your bilge, I would just use some degreaser. I use it all the time, and have never had any problems with it. It will break down any oil and grease that you have in there. Just spray let it set for a few minutes, and scrub if needed, and rinse. Make sure you have the nose up, so it will all wash out the drains holes in the back, and make sure that you have nothing blocking the drain holes.
    For the outside of the ski...as mentioen above, just wash it like a car.
    I totally agree on the pressure washer thing...no need for it.
    Retired...
    PWCToday.com Is My Home Away From Home FLWAVEBLASTER's Avatar
    Forest Lake, MN
    dont forget to honda wax it
    1994 WB1 Speedwerx boat
    1997 GP1200 stage 1
    WWW.THEFLPROJECT.COM
    WWW.TCJETPILOTS.COM
    WWW.USEDBOATWORLD.NET
    Frequent Poster Pro-pulsion's Avatar
    Mar 2009
    Ontario, Canada
    I cleaned my engine and compartment with regular old SprayNine and it came out looking amazing...still does actually. Plus it has a million other places you can use it like laundry even lol. It works very well on the laundry.
    lownrangr's Avatar
    Nov 2001
    Quote Originally Posted by FLWAVEBLASTER View Post
    hey good call. Not only will it protect for years to come, but it will add 3 mph.
    Region 6
    Shark Bait
    #713
    My race boats:
    Novice 1200 Stock
    1996 XP
    2015 Achievements
    Aug 2009
    Coldwater, Michigan
    Awesome Im waiting for a little bit better weather then I will try washing. Thanks for the tips. What works good for removing oxidation on aluminum aftermarket parts (flame arester, head ect) without removing the paint?
    Thanks again!
    PWCToday Regular photo4286's Avatar
    Aug 2009
    Cleveland, Ohio
    So are you saying that stopping at a Do-It-Yourself Car wash (with pressure washer bays made to be used on cars) is a bad idea??
