Results 1 to 6 of 6
    Aug 2007
    florida
    1100 stx di won't idle, help
    I got my 2000 ski working finally after 2 years and it will not idle. If I hold the throttle it will run between 300-6500 rpm's, but as soon as I let off the throttle it dies. I put new plugs in it and a newer fuel pump from an 03 model, help??
    Jul 2009
    indiana
    Re: 1100 stx di won't idle, help
    Have you tried adjusting your low speed screw?
    Aug 2007
    florida
    No I haven't. Is that the screw at the base of the box?
    Top Dog kawiski's Avatar
    Jul 2004
    So Cal L.A.
    Quote Originally Posted by doczuki View Post
    DI stands for Direct Injection - all computer controlled electronic fuel injection system on this 3-cyl 1100 STX. You will not find the low speed screw on this engine.
    Poor idling means usually you are running on either one or two cylinders only. You need a new ECU, aka EMM.
    Aug 2007
    florida
    I just had the EMM done by dfi and a new fuel pump. It has been sitting for awhile, so maybe bad gas.
    Jul 2004
    So Cal L.A.
    Quote Originally Posted by creativ43 View Post
    DFI rebuilt EMM may have been bad from the beginning or has gone bad AGAIN. EMM goes bad for a reason - the number one reason is overheating due to insufficient cooling water flow. EMM is extremely sensitive to the heat. That's why it is watercooled, which is extremely rare. You also must understand that's why there are two cooling water circuits on DI 1100 STX, one for engine and another for EMM via stator. If DFI guys did not properly program the fuel flow parameters (injector coefficients) into the rebuilt EMM, your engine would run either too lean or too rich causing idling problem. Time to knock on the DFI door.
    Fuel pump is either working or not working on DI skis. There is nothing in between and the bad ilding problem has nothing to do with the fuel pump. If someone suggested you replacing the pump, you'd better go knock on his/her door as well.
    Bad gas possiblity is easy to figure it out. Just replace with fresh one and see.
