Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    resident guru
    Jul 2009
    Floori.D.A.
    How do I change a 550 sx stator?
    1991, are there any topics already posted on this? Please direct me if there are. Anyone have any good info? Know nothing except that it needs one. Thank you.
    PWCToday Guru perryak's Avatar
    Apr 2008
    Juneau, AK
    Re: How do I change a 550 sx stator?
    It's on the front of the engine. Remove the gas tank, unbolt the flywheel cover, remove the flywheel. There will be wires from the stator you will need to follow to the back of the ski and unplug.
    '91 650sx - skat trac 15, rend plate/scoop grate, stock exhaust mod, drilled water box
    '92 550/650 conversion - boyesen reeds, stock exhaust mod, solas 14/19, OP big bore nozzle, WW freestyle cone, tri-scoop grate, OP skegged plate
    '96 Waveraider 700 - Just a couch
    PWCToday Regular SAO's Avatar
    New Jersey
    You will need a flywheel removal tool and holding tool to remove the flywheel. Hold the flywheel, loosen the 22mm(?) nut (first place a mark across the nut and the end of the crank with a Sharpie for reference when you put the nut back on; an air wrench is helpful, the spec torque is 120 lbs.), attach the removal tool to the flywheel, hold the flywheel, and crank it off. Some will hold the flywheel by putting a rope down into the front cylinder so that it keeps the crank from turning (I prefer the tool).
    Scott Obeck
    '94 Super Jet ...Group K F800SJ (84mm bore/754cc, milled head, ported cylinders, 200 psi), Factory mod b-pipe w/ Flow Control Valve, lightened flywheel, Solas Concord 13/17, MSD Enhancer, CarbonTech reeds. 52 MPH via GPS.
    '92 550 SX ...Group K Hammer, Factory 1/2 Pipe w/ Flow Control valve, lightened flywheel, 14/17.5 Solas prop, tubbies, Shred-Master ride plate. Docked in Diklo, Croatia, on the Adriatic Sea.
    '87 650 SX ...Ported cylinders, Mariner HC Head, Coffman full pipe.
    resident guru
    Jul 2009
    Floori.D.A.
    *dumb question* So I'm assuming I have to pull the motor out to do this...? Also what are the symptoms of a bad stator so I can be sure thats what it needs...? Thank you for your help.
    New Jersey
    I find it better to leave the engine in the hull to hold it stationary when you crank off/on the flywheel nut. There is no need to remove the engine.
    There is a cranking voltage test and a resistance test that can be done on the stator. How to and the specs for the tests are in the repair manual. I will try to copy the info and post it if you don't have the manual.
    Scott Obeck
    resident guru speedreed8's Avatar
    Jul 2004
    Tx
    resistance readings for the coils on the stator, can be checked at the cap on the elec. box., unplug connector check with a ohm meter.
    i would do this first before pulling it.
    Exciter Coil Red (or purple) & Black 112-168 ohms +/- 20%
    Pulser Coil Red (or purple) & Gray (or green) 14.4-21.6 ohmsPulser +/-20%
    Charge coil - Green (or lt brn) ----- Green (or lt brn) - 3ohms +/- 20%
    Green (or lt brn)-----Black - 1.5ohms +/- 20%
    __________________
    1988 JS550A7 modified, overhauled many times.., still riding @ my age, a little slower
    sbn44 w/OP stack, jetsport head (170psi), factory halfpipe w/ flow control valve,Impros 14.5 S/T impeller, bored nozzle. OEM crankshaft.
    T/R scoop grate, jetsport rideplate. seadoo 580 starter. advanced timing
    1997 750zxi (stock) boyesen power reeds>>sold
    1997 900stx (stock)>>sold
    1987 650sx >> sold
    1984 440 converted to R & R Jet tech stage 2 550 >>sold
    New Jersey
    There is also a cranking voltage test. Test the voltage between the grey wire and black ground while cranking the starter and also the red wire and ground in the same manner. Only problem is I do not know what the measurement should be. Maybe someone here on the forum can help with that, or call John at Jet Ski Solutions (678-255-5055).
    Attached Files Attached Files
    Scott Obeck
    resident guru
    Jul 2009
    Floori.D.A.
    Excellent!
    PWCToday Newbie kawi550sx's Avatar
    Apr 2009
    long beach NY
    any tips on how to get the flywheel off all i ahve left right now is the flywheel crank and crankcase i cant get this thing off
    Spongebob PWCToday.com Is My Home Away From Home attnondeck's Avatar
    Sep 2008
    Youngstown NY
    take the nut off. put a fly wheel puller on. tighten it very tight(i use impact gun to do it) then smack the fly wheel puller with a hammer if need be. should POP right off.
    Brendan
    1990 SN SJ 701 1990 SN Super Jet 650 Winter build
    1990 550SX
    1990 300SX
