Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    Jul 2009
    Fort Worth, TX
    Re: Replacing Fuel Lines in a 1997 Seadoo XP
    The 97 XP only uses 5/16 on the supply side. 5 feet will doo ya. The 1/4 inch will take 10 feet if you replace the vent lines also.
    Aug 2008
    Vancouver, WA
    Hi Guys,
    I hope some of you are still around because I decided to post some photos and ask a few more questions before I wrap up my carb rebuild and fuel line replacement project.
    Looking at the top of my fuel baffle, is it a bad idea to use hose clamps vs the stock fuel clamps? It seems like it's easier to find hose clamps vs the stock fuel line clamps... not to mention i don't need a special tool to install hose clamps. What do you recommend?
    Is it normal to have two different size of lines, 6mm and 8mm coming from the tank? One of my photos shows a little nipple in the line taking the size down from 8 to 6. Can I just run 6 or 8 mm everywhere?
    One of the small carb lines has a green in line "something." Is this another fuel filter? Also, what size are the carb lines? I would like to replace them as well.
    The last photo is a shot of my carbs. The book says to turn the low speed screw in until you feel resistance, then back it out one fuel turn. Should they screws be in the same position? When I back them off one full turn you can see that the heads do not not face the same direction. The book did not tell me how to set the high speed screw... does anyone know what this should be?
    Lastly, can I test the pop off pressure with the carb fully assembled? I have never done this test, but just picked up a tool to do so.
    Thanks in advance for any help you might be able to provide!
    -Matt
    Jul 2009
    Fort Worth, TX
    Two sizes off the baffle are normal. Large is supply, smaller is vent and return.
    Aug 2008
    Vancouver, WA
    Thank you! Do you happen to have any experience with the other questions as well?
    Jul 2017
    Michigan
    what kind of clamps should I use when I replace my fuel Lines ?
    PWCToday.com Is My Home Away From Home seadoodude's Avatar
    Cypress, Texas
    Quote Originally Posted by Bombardier97 View Post
    Use stainless steel screw hose clamps like you can get at auto parts store.
    also don't cut the old lines off or you risk scoring the nipples and causing leaks. I heated mine with a heat gun. Just make sure you don't have fuel fumes to explode. Work in well ventalated area.
    (2) 98 GSXLs
    (1) 00 Challenger 2000
