FAQs Updated
Results 1 to 9 of 9
Thread: FAQs Updated
    Aug 2008
    Boise
    FAQs Updated
    PM me if you think there should be something added
    I’m an old schooler so most of these links are for an older 90s SeaDoo
    ___
    SPARK 2014
    http://www.greenhulk.net/forums/forumdisplay.php?f=250
    http://www.pwctoday.com/showthread.php?t=411811
    Spark supercharger kit.
    http://www.pwctoday.com/forumdisplay.php?f=15
    Forum
    http://www.seadoospark.org/forum/sea...al-discussion/
    ____
    First get a free Shop Manual
    http://www.pwctoday.com/showthread.php?t=128441 or http://www.seadoomanuals.net/
    Clymers also has a good one. I use both because sometimes one is more clear than the other.
    88-96 years
    97-01 years
    Find OEM part numbers. Online Microfiche
    http://partsfinder.onlinemicrofiche.com/speedsupplies/Seadoo_oem/Seadoo_PWC.asp
    SeaDoo History
    1968-1969
    http://members.tripod.com/austin_ame...adoo/id21.html
    http://www.geocities.com/old_seadoos/history.html
    1989-2010 pics of each year's models
    http://www.seadoosource.com/seadoomodelreference.html
    G1 first gen two seater square nose
    G2 early thee seaters
    G3 second gen two seater
    X4 looks like G3 but with trim tabs on back
    CARBS
    SBN Carb Tuning for older ski
    http://www.pwctoday.com/f15/mikuni-s...ng-289786.html
    SBN Mikuni Manual (tuning tips and how it works from the source)
    http://www.mikuni.com/pdf/sbn_manual.pdf
    alternate link http://www.pwctoday.com/showthread.p...l=1#post915087
    SeaDoo Carb history & differences between BN, SBN, and BN “I”
    http://www.pwctoday.com/showthread.p...=1#post2715114
    Carb Rebuild guide (use mag for single setups)
    http://www.pwctoday.com/showthread.p...=1#post2671530
    Carb Rebuild Video
    http://www.shopsbt.com/forum/showthread.php?t=12004
    Clean the entire system when you rebuld carbs and replace N/S
    http://www.pwctoday.com/showthread.p...39#post3644739
    Stock carb settings
    http://www.pwctoday.com/showthread.php?t=62266
    SBN vs BN Carbs
    http://www.pwctoday.com/showthread.php?t=203175
    Mikuni SBN & BN Spring and Popoff Chart
    http://www.pwctoday.com/showthread.php?t=399915
    What is a lean seize
    http://www.pwctoday.com/showthread.php?t=232972
    Best description of lean and rich hesitation.
    http://www.pwctoday.com/showthread.p...=1#post2702788
    what is pop off pressure?
    http://www.pwctoday.com/showthread.p...=1#post2330118
    Build Pop-off tester- go to last page
    http://www.pwctoday.com/showthread.php?t=107996
    http://www.pwctoday.com/showthread.php?t=395845
    How to check pop off VIDEO
    http://www.shopsbt.com/forum/showthread.php?t=29016
    Removing the Carbs and Top End on a 2001 RXX Step By Step...
    http://www.pwctoday.com/showthread.php?t=412090
    Aug 2008
    Boise
    Re: FAQs Updated
    OIL
    What Oil to use? You'll see there is no clear answer. Just use what is rated for your Doo
    http://www.pwctoday.com/showthread.php?t=211366
    Oil filter
    http://www.pwctoday.com/showthread.php?t=201252
    Should I go premix? Never ending debate
    http://www.pwctoday.com/showthread.php?t=235786
    http://www.pwctoday.com/showthread.php?t=151113
    OEM oil pump used by pros with no problems
    http://www.pwctoday.com/showthread.p...=1#post3205054
    http://www.pwctoday.com/showthread.p...=1#post3609024
    Premixed motors blow up all the time. Premixing a ski does not make it bullet proof. I think it actually gives users a false sense of security and they do less maintenance.
    Here is just one blown up premix ski
    http://www.pwctoday.com/showthread.php?t=337853
    The pumps never fail, but people don't maintain their ski and the lines get brittle and break. That's what causes the problems. If you have skis that are premix, then yes go for it, because it is not a big deal for you.
    VTS info and repair
    Bad motor
    http://www.sea-doo.net/techarticles/vts/index.html
    300 ZX left door window motor. Half the price of a Sea Doo VTS motor. Same motor.
    VTS bypass with good motor and bad relay
    http://www.pwctoday.com/showthread.php?t=226216
    Rebuild your VTS module for $33 or by one for $70
    http://www.pwctoday.com/showthread.php?t=280433
    $70 kit is verified as working
    http://www.pwctoday.com/showthread.php?t=282822
    trim fix cheapo way
    http://www.pwctoday.com/showthread.php?t=295371
    Aug 2008
    Boise
    Aug 2008
    Boise
    Re: FAQs Updated
    Aug 2008
    Boise
    Re: FAQs Updated
    MISC
    what you need to rebuild a crank
    http://www.pwctoday.com/f21/crank-re...ml#post3374063
    Starter don’t work, just rebuild it (plus starter removal tips)
    http://pwctoday.com/f15/just-replace...ay-244346.html
    MPEM Bypass
    http://www.pwctoday.com/f15/mpem-bypass-345475.html
    Keep breaking exhaust bolts?
    http://www.pwctoday.com/f15/exhaust-...ml#post3251453
    Were to buy gelcoat and some application tips
    http://www.pwctoday.com/f15/does-any...at-358900.html
    Replace that red start button for just a few bucks
    http://pwctoday.com/f15/red-button-thingy-230349.html
    Where does this hose go?
    http://pwctoday.com/f15/lost-hose-231428.html
    SBT Videos. Good overview
    http://www.sbtontheweb.com/forum/forumdisplay.php?f=23
    Tubing (pulling one on a two seater)
    http://pwctoday.com/f15/tubing-possible-224220.html
    old yellow 580 G1 hull. Just got one, here’s what to work on before you start. Has no spark and carb tips as well. Great story from Bill O on racing a G1 hull.
    http://www.pwctoday.com/f15/1989-sea...-a-261752.html
    Differences between 657 and 657x
    http://www.pwctoday.com/f15/657-vs-6...on-262412.html
    951 White motor VS Silver
    http://www.pwctoday.com/f15/people-d...ml#post2944491.
    Bill O’s way to get water out of a flooded motor
    http://www.pwctoday.com/f15/seadoo-5...ml#post2696427
    how often to clean RAVEs
    http://www.pwctoday.com/f15/98-gtx-l...ml#post3249355
    Get towed and don’t skink. If you break down or are just tied to a boat
    http://www.pwctoday.com/f15/my-shut-...es-178520.html
    Buying tips
    http://www.pwctoday.com/f34/buying-used-pwc-62273.html
    just got your ski.. what to check first
    http://www.pwctoday.com/f15/1999-gtx...ml#post3302171
    cheaper BUDDS
    http://www.pwctoday.com/f15/seadoo-s...ds-343484.html
    Old 580 flywheel and starter suck?
    http://www.pwctoday.com/showthread.php?t=373064
    Don’t mess with your filter or carb unless you know what your doing
    http://pwctoday.com/f15/how-much-abu...-229540-2.html
    Just didn’t listen to advice
    http://pwctoday.com/f15/96-xp-fouling-138360.html
    How not to ask questions
    http://pwctoday.com/f15/need-help-sk...se-218262.html
    Never by a ski that “just needs a new starter/battery” (even though I did)
    http://www.pwctoday.com/f15/fair-price-320313.html
    Don’t by cheap Ebay starters DB Electrical
    http://www.pwctoday.com/f15/lesson-l...rs-332846.html
    SBT starters OK
    http://www.pwctoday.com/f15/constant...ml#post3380465
    Old school thread (should be midish 90 and down with two strokes)
    http://www.pwctoday.com/showthread.php?t=137266
    Cup Holder Install
    http://www.pwctoday.com/showthread.php?t=217407
    How to ride a HX
    http://www.pwctoday.com/showthread.php?t=375664
    Finger Throttle on Doo
    http://www.pwctoday.com/showthread.php?t=377851
    Inspect your trailer
    http://www.pwctoday.com/showthread.php?t=396895
    MicroTouch manuals
    http://www.pwctoday.com/showthread.php?t=421664
    Repair a leaky two piece oil tank
    http://www.pwctoday.com/showthread.php?t=466924
    Aug 2008
    Boise
    Re: FAQs Updated
    The X4
    X4 Hull Years
    http://www.pwctoday.com/showthread.php?t=201839&page=2
    X4 Development History (ignore the other banter)
    http://www.pwctoday.com/showthread.p...=1#post2905821
    Aug 2008
    Boise
    Re: FAQs Updated
    cleaned up
    Aug 2008
    Boise
    Re: SeaDoo FAQs Update
    cleaned up
