03 turbo problems
Results 1 to 8 of 8
    Jun 2009
    Ithaca NY.
    03 turbo problems
    Ski runs fine except the turbo is not working.The waste gate is free but it does no move . Any ideas ? Thanks.
    Jun 2009
    CT
    Re: 03 turbo problems
    I had the same problem with mine just last week. Take the blk cold exhaust hose with the two silver hose clamps off and look into the impeller inside the turbo and check to see if u can spin it with your finger freely. Mine wasnt spinning at all and was only just stuck from oxidation over the 3yrs it wasnt used. If it isnt spinning then use a deep tube 9mm socket and give it an easy turn to the right preferably and see if u can loosen it up. U shouldnt need any kinda of lube to loosen it up. Once loosen it should spin freely with an light push of ur finger.
    Jun 2009
    Ithaca NY.
    Quote Originally Posted by squeak14 View Post
    Thanks im going to try that. I will let you know how it goes.
    Jun 2009
    Ithaca NY.
    The turbo fan spins freely. Think it might be the wastegate solenoid.
    Jun 2009
    CT
    Well that was all i got for ya b/c im bran new to the honda pwc industry, but im sure others on this site will have other suggestions for u. JUst check to make sure the wastegate rod going into the turbo is well lubricated with crc
    Mar 2005
    Austin, TX
    You really need to use a boost gauge.
    It will not build boost when it's on the hose and not under load.
    Even with a bad wastegate solenoid, it should still build some boost - I think 8-9 PSI.
    1brokeazzhonda
    Guest
    I have a wastegate housing for sale
    Jun 2009
    Ithaca NY.
    Thanks for all the help it was the wastegate solenoid.
