    May 2009
    oklahoma
    94 SPI starts but wont stay running
    starts but wont stay running...replaced fuel lines and spark plugs...any ideas?
    May 2008
    florida
    Re: 94 SPI starts but wont stay running
    Pull the air breather plastic assembly off and run til it quits. Open gas cap and
    that will relieve any pressure. Pull off the fuel return line and put it in an emty
    bottle and crank engine. Fuel should route. POST result.
    May 2009
    oklahoma
    thanks for the info but can you be a little more specific? which end of the return line do i take off and am by doing that, am i trying to fix it or just running a test?
    May 2008
    florida
    My bad. Pull the carburetor end of the return line from where it attaches to your carb
    This is a fuel route test. A point to begin and back-track to the problem, be it the
    carbs gummed up, fuel inlet clogged at inlet nipple, selection valve clog, lines will
    clog at connect points. You can put a short piece of hose on the carb return nipple
    and into a catch bottle if your fuel does route. Post 2 alerts you that the fuel system
    is pressureized. NO relief of pressure by removing the gas cap means the check
    valve failed. NO route means you need to continue back-tracking and remove the
    fuel line from the inlet supply side of the carb, place that line in your bottle to catch
    fuel if it comes out. You then apply air pressure into the return line to check if you
    have routing in the line system. IF fuel routes into the bottle, that indicates the
    problem is carburetor or a clog in the pulse line from engine block, or both. AFTER
    you find your problem, fix it or replace it. Hope this helps
    May 2008
    florida
    Here is a link to Dominicks: www.seadoosource.com seach his mikuni
    section for pictures of the carb return/supply nipples orientation.
    Please post your results it may help other members
    Feb 2004
    Glendora, California
    Does it have BR8ES or BR7ES sparkplugs in it ? Because if it does not have BR type sparkplugs in it, it will not continue to run after you start it.
    Check the easy stuff first.
    May 2009
    oklahoma
    yeah it has BR8ES
